Ed
team: Stealth
| Author | Subject: 283 belled discs |
eddiebeano
Senior User Location: Edinburgh Registered: 31 Dec 2008 Posts: 715 Status: Offline |
Does anyone know if you can get standard size discs that use bells? The closest I've seen are 285, and thicker.Ed ________________________________________ team: Stealth |
I can't remember how thick the standard discs are but hispec seem to have rotors listed 24mm and 26mm thick. http://www.hispecbrake.co.uk/ The site didnt seem to be working when i tried it earlier though. ________________________________________ Goldie the track car. |
22mm________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
eddiebeano
They don't list 22mm ![]() ________________________________________ team: Stealth |
can't have belled discs from then then...ask phillipm, he might be able to knock some up from nicked drain covers. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
allanallen
Seasoned Pro Location: Buxton Registered: 01 May 2007 Posts: 1,399 Status: Offline |
Some Standard discs can be turned into rotors fairly easily. If your caliper can accomodate it you could also look at using wider rotors and machining the pad face down to suit.________________________________________ www.bridgecraftmotorsport.co.uk |
eddiebeano
allanallen wrote: tell me more about this.. I'm using wilwood midilite calipers..Some Standard discs can be turned into rotors fairly easily. If your caliper can accomodate it you could also look at using wider rotors and machining the pad face down to suit. ________________________________________ team: Stealth |
allanallen
Find an off the shelf disc with minimal offset, accuratly bore a big hole throgh the centre then drill the pcd of holes to suit your bells. Im sure ive seen it done with a gti6 disc to be honest. Or as i say the other option would be to use say a 24mm rotor if itll fit in your caliper, i know hi-specs usually except a wider disc.________________________________________ www.bridgecraftmotorsport.co.uk |
They'll be made for a 25.4mm disc if they fit over a standard 306 disc, the smaller one is 21mm, or 12.7mm.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
allanallen
welshpug! wrote: They'll be made for a 25.4mm disc if they fit over a standard 306 disc, the smaller one is 21mm, or 12.7mm. Problem solved then ![]() ________________________________________ www.bridgecraftmotorsport.co.uk |
