Author Subject: Big rear brake conversion
pugheaven
As above im after a bigger set up for the rear brakes to fill the wheels a bit as the standard rears look stupid on the dimma, even more so with the 330's up front!
I know they are not needed but I'm just doing it for looks.
Thanks
Ollie
Posted 12th Mar 2012 at 16:33
simonjames
I have some 406 coupe 295mm (iirc) calipers and discs only handbrake is run of shoes (drum built in on disc) £40 delivered
MY EBAY ITEMS
07943066306
Posted 12th Mar 2012 at 17:39
Bargain
Posted 12th Mar 2012 at 18:03
pugheaven
Thanks simon I'll do a little research on that setup, can you use 306 hand brake cables? So the discs and drums are one unit just bolt onto the rear hub? Take it the calipers mount to the original lugs?
Posted 12th Mar 2012 at 19:35
pugheaven
Sorry just realised u said the drums are built into the disc! Do the calipers use the original mounting points?
Posted 12th Mar 2012 at 19:38
simonjames
TBH i dont know i bought them off a breaker to fit on my rallye but when it came to fitting i opted for the easier standard discs and pads
MY EBAY ITEMS
07943066306
Posted 12th Mar 2012 at 19:57
pugheaven
Oh ok I'll get back to you about these then once iv done some research.
Posted 12th Mar 2012 at 20:10
Devere on here had an uprated rear setup, worth a PM.
Posted 13th Mar 2012 at 08:12
Ed_van_dijk
I was told you can fit the fronts off a 205 on the rear, bolts straight on, dunno how the handbreak would work though
Astor 6
Posted 13th Mar 2012 at 11:58
handbrake wouldn't work Wink
you can fit a vented 205 disk to the rear by using Bendix vented disc pad carriers rather than the solid disc pad carriers, the centre bore of the disk will need enlarging, same diameter though LOL
you may be able to fit a caliper from a larger Citroen as they have front handbrakes, though you'd need to rebuild them if they're from certain older vehicles as they used LHM fluid not DOT fluid.
Posted 13th Mar 2012 at 12:07
pugheaven
Was just thinking about the front brakes on the xantia active as like u said the hand brake is in the front, Only problem then if they fit is the handbrake cables will be entering the caliper from the rear so routing them may be interesting!
Posted 13th Mar 2012 at 14:04
c_j_m
C5's have the hand brake on the front also.
They have a twin piston rear setup as well, but not sure on disc size.
Posted 13th Mar 2012 at 15:03
276mm disc, quite deep offset by the looks of it, twin 32mm pistons so no larger than the 306 piston, front brakes are either 283x26 or 288x28, they are Fahooking heavy though, there's a few lower sped 266x22 disc setups.
Posted 13th Mar 2012 at 15:28
mr swampy s16
**BAD SELLER**
willwood used to do a caliper that you can fit a cable hand brake on
bet they wont be cheap though
Posted 13th Mar 2012 at 19:27
eskiiboi
Clicky
Obv not for a pug but shows they are out there Wink
EDIT:
BINGO
Says a maximum vehicle weight of 750KG's though?
Posted 13th Mar 2012 at 19:34
they're too small for most cars, limit of 750 kilos.
might be worth looking at 405 rear calipers.
edit, no point, same diameter a a 205+306 LOL
Posted 13th Mar 2012 at 19:38
pugheaven
I know willwood did some and think Hi Spec did some too but like you said alot of money.
Welshpug are you talking about the c5 front set up?
Does anyone know if the calipers will fit the rear of a 306 and if the discs would be central tooth caliper or will the offset be wrong?
Posted 13th Mar 2012 at 19:41
pugheaven
Tooth- to the
Posted 13th Mar 2012 at 19:49
eskiiboi
But they look the same as the ones on the link I posted above it? What is the difference? Thought I found a winner Sad
Posted 13th Mar 2012 at 19:52
pugheaven
Ok so they are not that much money but then would still need to get brackets made to suit what ever disc I used, I'm trying to find a cheap way of doing it.
Going to look into ford parts too, might be worth a day at the scrap yard trying different parts
Posted 13th Mar 2012 at 20:07
miles
AP used to do a set up on the rear, Won;t be cheap but won't be beaten
www.pugracing.com
Posted 13th Mar 2012 at 20:49
