Author Subject: Induction/throttle body question..
braymond
I'm going to be changing my induction setup in the coming weeks, with cold fed system fitted directly onto the throttle body.
Can anyone tell me what the additional little pipe (white arrow) is for and what it connects to (red arrow)? This will obviously be gone if i simply fasten a 90deg elbow onto end. Will it be a problem? Whats its function?
Rallye-R
Nurburgring article
Posted 11th Mar 2012 at 17:06
its for the idle valve, does need to be filtered.
Posted 11th Mar 2012 at 17:09
braymond
Any suggestions? (without saying keep the existing setup...)
Rallye-R
Nurburgring article
Posted 11th Mar 2012 at 17:10
K&n mini filter. Load of setups like it on here.
Posted 11th Mar 2012 at 17:12
attach filter to the end of the standard intake elbow.
braymond
Thank you
Rallye-R
Nurburgring article
Posted 11th Mar 2012 at 17:14
stu
Here's how mine is setup......
The filter I used wasn't exactly mini though, still does the job and that's all that matters!
Posted 11th Mar 2012 at 17:23
clen666
I think that's the same filter that I have Stu, bigger than expected when it arrived!
Team 'unintentional rat look'
Posted 11th Mar 2012 at 17:26
braymond
Thanks.
I think I'm more seduced by using the existing intake elbow though. Seems to tick all the boxes for me.
Rallye-R
Nurburgring article
Posted 11th Mar 2012 at 17:27
stu
Laugh
Yeah, did take me by surprise when I opened the box......
braymond
Just to tag another couple of questions on the end of this topic,
Q1. If I remove the top radiator hose for easy access, am I going to invite a load of air into the system or will it just be alright?
Q2. I'm sure I've read that people have had to relocate horns and something else from the general area where pipework will be routed. Can anyone give more details on that or is this something a rallye user need not worry about?
Rallye-R
Nurburgring article
Posted 20th Mar 2012 at 15:51
stu
You should be able to do it without removing the rad house, more hassle than it's worth taking it off IMO.
I didn't need to do anything to the horns on mine, depends how you want to route the pipework though I suppose.
Posted 20th Mar 2012 at 15:55
braymond
Did you have any interference with the arch liner?
Rallye-R
Nurburgring article
Posted 20th Mar 2012 at 15:58
stu
No
I just moved it out the way so I could see what I was doing a bit better during installation, but apart from that it was not affected at all.
Posted 20th Mar 2012 at 16:02
braymond
Thanks Stu
Rallye-R
Nurburgring article
Posted 20th Mar 2012 at 16:03
stu
No problem.
Stick some pics up when you're done. Thumbs up
Posted 20th Mar 2012 at 16:04
braymond
I shall. I'll update my project thread
Rallye-R
Nurburgring article
Posted 20th Mar 2012 at 16:08
I've modified the snorkel set-up on mine to make it a cold air feed,rather than it sucking hot air from behind the grilleWink
Removed resonators from airbox and blanked off the hole,and fitted a Ram-Air induction filter inside the standard air boxThumbs up
Works a treatBig grin
Posted 20th Mar 2012 at 16:21
lewisdmz
I'd bet money the standard snorkel is more efficient. Good idea about putting a cone filter in the airbox though, I miss the noise mine made.
Posted 20th Mar 2012 at 18:25
I don't think soThumbs up
Car did 180bhp at a rolling road day,was the most powerfull standard injection fitted Gti6 on the dayWink
Posted 21st Mar 2012 at 16:26
lewisdmz
I'm guessing you have other engine mods to get 180bhp though?
The standard snorkel is a ram air it just picks the air up from about 3 inches lower down than your modded one does. Can't imagine it would be picking up warm air at all considering it is well in front of the rad...
Posted 22nd Mar 2012 at 00:11
Magnex de-cat and system,and before you say anything there was a few people off here there when it made that power!Razz
The standard snorkel is not ram airLOL
How can it be when its facing down and there is no holes in the grille/bumper for air to go into it???????No
Posted 22nd Mar 2012 at 16:53
Double postRoll eyes
Dodgy forumYes
xsi_lew
slightly off topic but heres how mine is setup:
Posted 22nd Mar 2012 at 17:29
