Author Subject: bulkhead heatsheild
burnout21
I am wanting to know what danger do I have of driving my car without having the bulkhead heat shield on? the one I have on has partly burned a hole through the foil. It is a bit on the butchered side. I'm going to repair or maybe replace it but need to drive car still. The bottom bolts are missing after having my headgasket done, So it has ended up resting on the manifold. I don't want to carry on driving it with it resting on the manifold. So back to the main question, is it safe to run without it?
Posted 10th Mar 2012 at 10:57
Not really, fuel pipes, brake lines and all sorts of essential stuff are protected by the heatshield, keep the journeys short and switch of if you have to stop for any delays in traffic But get it replaced ASAP
Posted 11th Mar 2012 at 17:32
you'll be fine without it, I never got round to fitting one on my ZX that was converted to gti6 engine, no issues in 12k.
Posted 11th Mar 2012 at 17:43
Just as a heads up, these were quite expensive around £110 I think from the dealers and albeit they aren't available anymore. No
So, your options are either buying a decent condition second hand one or there are some people who have had them made up and shaped properly in stainless steel. Yes
Posted 11th Mar 2012 at 18:06
burnout21
Cheers for the advice guys Thumbs up
See if can find one and fit it. Not easy to fit with the manifold on though. Sad
I did look at the metal fabricated heat shields on here but can't justify the price at the moment as
I have still a few other things to fix on the car..
Posted 11th Mar 2012 at 18:47
Will look the pictures out of my project thread, but mine was going tatty round the edges and to avoid it catching fire, I have repaired one using some heat foil tape.
Much cheaper alternative Yes
Posted 14th Mar 2012 at 10:33
eddy_gti6
I am running my gti6 with no heay shiels and my old rallye didnt have one either. I have not jas a problem yet and fingers crossed it stays that way. I have one to put back on when i get a chance tho.
Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url &amp; =
Posted 14th Mar 2012 at 10:45
The stainless ones are cheaper than getting a burned out car recovered.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 21st Mar 2012 at 18:23
Personally I'd wrap the manifold before even considering not running with one. Although it "should" be fine. I'd just rather not worry
Posted 21st Mar 2012 at 18:36
It's been put there by Peugeot for a reason...
They wouldn't have fitted it if it wasn't necessary...No
Posted 21st Mar 2012 at 20:07
burnout21
That is the Argument I had with my Uncle, but I will get it sorted, just got to wait for someone breaking a car with one in good condition. Buzzbrightyear, I was tempted by the fabricated one but I have a few other parts to replace and I feel they are a bit more important money wise. I think only driving short distance It 'should' be ok till can replace it.
Posted 21st Mar 2012 at 20:26
