Author Subject: Phase 3 306 1.6 Conversion to 2.0l gti6
Teshboi1988
right heres the crack
i had a 306 1.6. gearbox kinda exploded...
so looking on ebay found a guy who sold me a gti6 engine conversion kit... ecu, loom, gearbox etc...
so then i converted to the gti spec....
suspension brakes exhaust, subframe steering rack etc
whilst i had engine out i thought id wack some wossner pistons in, n do the whole shabang n replace all the bits that wear..
bigends smallends
stem seals..
new gaskets
new crank n cam seals
cambelt
auxbelt
had engine block bored out
had head skimmed
flywheel skimmed
new clutch (proformance)
everything has been cleaned
and serviced it
got ecu programmed to key...
n boom it started...
but.....
its running shit, its idling at 20 then slowly dies n cuts out....
HELP
phase 3 Hatchback V reg 5Door GTi6
Posted 10th Mar 2012 at 09:21
mcfc1987
welcome noob. unfortunately you won't get any technical help until you pay for membership and post In the correct section. its worth the fiver for all the knowledge on the forum
Posted 10th Mar 2012 at 09:29
Teshboi1988
lool dint no that so yea 1st time on here lol ok fiver for how long??
and how do i go about paying it
Posted 10th Mar 2012 at 09:30
Fiver gets you a year bud and click on membership on the home screen Thumbs up
Posted 10th Mar 2012 at 09:40
Teshboi1988
got that gold membership lolbut my pics are too big too upload grr
Posted 10th Mar 2012 at 09:50
asim_pug306
Upload them to photobucket and then copy them across using this IMG code
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 10th Mar 2012 at 17:30
You say you have Wosser pistons in. Are they low/high compression items, and no other bits fitted?
For example, high compression if you have changed to lairier cams, or low compression if you have added forced induction, turbo or supercharger.
If this is the case, I would imagine thats why its not running properly Hmm
Posted 10th Mar 2012 at 18:04
High comp pistons you would have thought ?
Posted 10th Mar 2012 at 18:17
Moved to Engines. Smile
Posted 10th Mar 2012 at 18:21
Teshboi1988
yea high comp pistons.... sorry bout the 2 threads dint even realise i made 2. im sucha noob lol my bad.
Posted 14th Mar 2012 at 07:59
Have you fitted high or low comp pistons?
In this thread you say high, in your other thread you say low.
Either way as previously discussed, this is your problem and it isn't going to go away unless you put the original pistons back.
Posted 15th Mar 2012 at 23:56
