Author Subject: turbo conversion
6666
Hi here is my second 306 bought it last week 306 td tidy shell and good price i was thinking of fitting a v6 in my 6 but found this and decided to use this and keep the 6 standard,i looked around at the v6 conversions but lost interest in that idea and ended up buying a 2.0 8v turbo from a 406 i know there not the best motors but for the price of the car and motor should be a tidy weeked toy for less than 1k.
Any info on the turbo conversion would be much appreciated.
Posted 9th Mar 2012 at 20:31
jay vts
sounds interesting, would be good to see how the engine compares with the gti-6
Posted 9th Mar 2012 at 20:35
darzmat
have a search, there are a couple posts regarding the 8v turbo, i read through them not that long ago. maybe find some info you will need,
what sort of power are they standard?? i think you can get them up to 220bhp without spending too much
Posted 9th Mar 2012 at 20:42
midlife
There's a guy breaking an 8v turbo in the formsale section, everything u need
Cool
Team 330™Cool
Team "no front end or engine"
Posted 9th Mar 2012 at 20:47
6666
Cool
cheers will take a look
Posted 9th Mar 2012 at 20:48
6666
think they are 150 bhp will be getting refresh and a few bits done just to run safe boost till next winter then will be going for higher boost
Posted 9th Mar 2012 at 20:55
fatlapit
I ran a bar of boost for 240hp. but i ran a charge cooler. bit of a marmite engine but i like marmit. hardest bit is the wiring. apart from that an easy conversion imo
Posted 9th Mar 2012 at 21:48
clen666
I think your handbrake cables need adjusting!
Team 'unintentional rat look'
Posted 9th Mar 2012 at 22:23
I'd worry about the ride height before the handbrake cables LOL
Posted 9th Mar 2012 at 22:32
6666
nowt wrong with ride height is there hahah will be fitting a 6 torsion bar with a sensible drop
Posted 10th Mar 2012 at 14:21
6666
No cables fitted to car or rea beam
Posted 10th Mar 2012 at 14:23
6666
collected engine today hopefully get it stripped down next week for a freshen up
Posted 10th Mar 2012 at 20:47
bellcp306td
looks cool. good luck with it
Where did the road go!
Posted 13th Mar 2012 at 13:58
JWP EFi
Turbo Legend!
i must admit, she looks good with the speedlines! bit low though, handling will be shocking!!!
Posted 17th Mar 2012 at 22:18
miles
The 6 engine will make the 8v turbo engine look silly in std trim, up the boost slightly and you will see around 200bhp, but it's like driving a Derv with the small turbo and lack of a power band even with after-market management fitted,
Having driven pretty much every Pug engine going I hate to say this is by far the worst of the lot
www.pugracing.com
Posted 17th Mar 2012 at 23:46
eddy_gti6
Nice thread. I started putting one of these engines in one of my gti6s then got bored and sold it all and broke the car? LOL you got anything done to the engine. Get a 1.9 205 gti cam fitted and an evo intercooler and you can up the boost to around 20psi then you should be pushing around 220bhp Big grin
Posted 18th Mar 2012 at 11:16
fatlapit
should be hitting 220 at a bar any way
Posted 18th Mar 2012 at 11:59
6666
cheers for your feed back iam not expecting super car power from this engine in standard form but times not an issue so have pleanty of time to decide what spec i will built it to.
Posted 21st Mar 2012 at 17:20
6666
yeh was low but beam has been removed now will be replaced with a rebuilt 6 beam and a more forgiving ride height
Posted 21st Mar 2012 at 17:23
6666
Ran a compression test before i began stripping the engine down the compression was down on one cylinder 150/90/150/150 going to get the head tested before weekend they move on to the bottom end
Posted 21st Mar 2012 at 17:29
6666
Bit of an update stripped the head down to find two bent valves and knackerd oil seals every valve having alot of build up on them and the valve seats which solves the cylinder down on compression, ordered four new inlet valves cleaned head and ports up and ground the valves back it just waiting on a new head set to be delivered which have been a right pain trying to source, hopefully have it for the weekend and get the engine built back up and trial fitted,
Then decide what turbo and manifold set up to go for.
Posted 29th Mar 2012 at 21:05
