cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD
Black p3
| Author | Subject: Fooking washer jets |
swiftyboi006
The washer jets dont spray, the pump works as it makes noise. The problem is....i cant get the kents off. Can someone enlighten my stupidity please________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
sharvey44
Senior User Location: East London Registered: 22 Feb 2010 Posts: 795 Status: Offline |
pull the pipe off from the jet under the bonnet. check water comes out the pipe.if so use brute force to remove jet from bonnet. i think you should be able to push them from underneath. either clean or replace with Xsara mist jets.. ________________________________________ Ph2.5 Nile - Slowly trying to de-East London it and restore to former glory...Built on the 9 Febuary 1999 - Tuesday's car..is full of pace? ![]() Currently looking slightly molested due to some c*nt trying to get into it.. ![]() According to the forum Social Worker, because I work in IT, I am socially retarted.. |
swiftyboi006
Cheers mate yes the pipes are all clear just the jets must be blocked i have tried to get them off befor but i didnt want to damage the bonnet, ill give it another go with some muscle ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
shove a 10mm socket over the back of it.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
You can pinch the clips on the sides of the jets on the underside of the bonnet with a pairs of pliers and then pull the jet out from the top. ![]() As stated already, replace with Xsara mist jets, they are much better. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
swiftyboi006
Getting sick of stans help......________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
Just replace, the bas**rds block constantly once you've had trouble wit them once. ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
mpieczko
Regular Location: Birmingham Registered: 11 Mar 2009 Posts: 236 Status: Offline |
I always find using a small needle often cleans them out a treat. But as everyone has already said, they are so cheap to replace. Get the Xsara mist jets, they have been brilliant in the time that I have had them. |
mrdeey
Regular Location: nearerthanuthink Registered: 14 Feb 2011 Posts: 200 Status: Offline |
Xsara mist jets.. , much much better , get a bull dyke to push the old ones out if you carnt do it!________________________________________ now new booted , boosted and flying again! |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
My front and back blocked and just used a .5mm drill in my hand to unblock________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
miki4
Regular Location: Cologne Registered: 09 Nov 2015 Posts: 393 Status: Offline |
Mine were also blocked in my first 306. You could free the jets with a needle (you can aim them with the needle while you're at it) but they would keep getting blocked regularly so I took them out and soaked them in some vinegar to solve any scale, cleaned them and put a small scooter fuel filter in-line. I cannot tell how durable that solution is as I replaced the washer jets with the xsara ones a month later which have a nice spray pattern that covers most of the windscreen at once. But you should see the s**t inside the filter after five years. However I would not put a fuel filter there again because you get a delay of about one second until water comes out of the jets. -> XSARA JETS plug and play is the way to go. |
RetroPug
Major thread bump haha.If you are getting dirt in the system remove the washer bottle and see if it is dirty. When I bought my 306 I was having issues and there was a solid mass of green algae in the bottom inch of the bottle. It was disgusting and all came out in one giant blob. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
sageman
Regular Location: Norwich Registered: 23 Jan 2016 Posts: 114 Status: Offline |
i had a strange white jelly in mine just keped the sprayers on till it all came out (there wasnt much) then a bottle of white vinigar and topped up with water ________________________________________ 1976 Reliant Kitten1985 Reliant Fox Tandy campervan 1998 GTI-6 1993 Citroen XM sei V6 (barn find) |
miki4
sageman wrote: i had a strange white jelly in mine just keped the sprayers on till it all came out (there wasnt much) then a bottle of white vinigar and topped up with water Maybe a previous owner wanted a baby 306... |
miki4
RetroPug wrote: Major thread bump haha. Did not even notice that. |
