Author Subject: Engine Cut out and wont start
tony eastwood
It has fuel and a spark but will not even try to fire up when i turn it over. any ideas would be greatly appreciated
Posted 5th Mar 2012 at 11:22
Crank sensor could be dead - does the rev counter move up when you try to start it?
The crash ball bearing thing on the right hand of the engine bay hasn't been activated has it? Can't remember what its called, but then you'd not have fuel...
Posted 5th Mar 2012 at 11:34
tony eastwood
the rev counter goes mental, i thought crank sensor but would it still have a spark that you could see on the spark plug if the crank sensor was gone? cheers
Posted 5th Mar 2012 at 11:36
"inertia switch" is the engine bay switch
Posted 5th Mar 2012 at 11:37
tony eastwood
ill google that rikky and see what it does, thanks
Posted 5th Mar 2012 at 11:39
tony eastwood
theres fuel though, im baffled
Posted 5th Mar 2012 at 11:40
if the rev counter goes nuts I'd imagine the battery is a bit tired, or the alternator isn't charging and it simply hasn't the guts to turn it over fast enough to start.
needle going apeshit usually points to voltage problem
Posted 5th Mar 2012 at 11:41
tony eastwood
batterys good but what would cause a voltage problem? maybe its not good after all
Posted 5th Mar 2012 at 11:42
Do a drop test on the battery and see if it holds out. Wink
Posted 5th Mar 2012 at 18:25
fatlapit
i assume u were driving when it cut out, did the battery light come on first?? but i`m pretty sure if your engine is running and it cut out i doubt it will have nothing to do with the battery as the car was running off the alternator.
Posted 5th Mar 2012 at 18:57
swiftyboi006
Sounds like a sensor to me. I would have said crank but i dunno. Bigbadbowen will have 1 for a good price if you pm him
Black p3 Love
Posted 5th Mar 2012 at 20:15
my car did this (was a little low on fuel)
I towed it home and it started in the morning first time. I then filled it up and its done 1500 miles since.
Usually though this sort of thing is Battery, Fuel Pump or fuel pump relay. Which is why i bought all three as spare from pugplus and keep them in my boot
Posted 5th Mar 2012 at 20:23
