as you all know the harmonic pulleys are crap and the outer spins, i have a brand new 2l 8v turbo crank pulley to use to time up the motor providing its good!
| Author | Subject: pulley question |
fatlapit
are the gti6 crank pulley the same as the 2l 8v turbo one??as you all know the harmonic pulleys are crap and the outer spins, i have a brand new 2l 8v turbo crank pulley to use to time up the motor providing its good! ________________________________________ |
tony eastwood
Newbie Location: Selby Registered: 20 Jan 2012 Posts: 35 Status: Offline |
dont know |
also don't know________________________________________ Membership expiring soon, get in contact on our new little forum project. |
fatlapit
any one?________________________________________ |
I think they are the same, but the offset, diameter and number of grooves might be different, ask Miles as I think he knows them.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
fatlapit
im hoping the timing marks/holes are the same________________________________________ |
info@pug1off.com
Newbie Location: Brackley Registered: 24 Sep 2011 Posts: 46 Status: Offline |
Diferent offset to accomodate the differnt belt width, but the mark will be the same....all pistons level with 1 and 4 rising in the direction of rotation if you ever want to check the accuracy of a pulley!________________________________________ N/A XU10J4RS = 302.1 bhp / 184.2 lb.ftTurbo XU10J4RS = 500.2 bhp / 443 lb.ft USC 2011 Double Class winners N/A FWD 0-60 winners at TRAX 2011 Developers, stockists and installers of superior upgrades for the Peugeot 306 GTi6 & Rallye, including:- *NEW!!!!! 4.8:1 final drive for BE3/6 *BBM Group N engine mounts *Cat Cams and vernier pulleys *Emerald ECU's *Jenvey throttle bodies *Uprated gear linkages and short shifts *Quaife & Tran-X LSD's for BE3/6 *Tar-Ox brake discs and Ferodo DS2500 pads *Solid rear beam mounts *21-25mm torsion bars *25mm rear anti roll bars |
fatlapit
info@pug1off.com wrote: Diferent offset to accomodate the differnt belt width, but the mark will be the same....all pistons level with 1 and 4 rising in the direction of rotation if you ever want to check the accuracy of a pulley! also when timing the gti6 motor with the stock adjustable cam pulleys, how do you set the pulleys?? are they set the same?? or fully advanced or retarded?? how much to set the timing lol for a turboed motor?? ________________________________________ |
neither, you pin the bottom, pin the top, swing the pulleys forwards the fit the belt, tension the belt then tighten the bolt/s on the pulleys.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
fatlapit
oh i see the cams are hels when you tension the belt so the timing cant slip??________________________________________ |
the cams are pinned but the outers can move.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
fatlapit
coolio and always use 136 belt kit yeah________________________________________ |
I prefer to use it yeah, as do most engine builders I know of.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
