I can see where it goes in my Sony head unit its connected to the blue/white wire, but my pioneer headunit (DEH-P9600mp) does not have a blue/white wire, only a "wired remote input" 3.5mm jack, could this be where it plugs into ???? I'm Confused
| Author | Subject: Amp to Headunit wiring problem |
roddo
Newbie Location: Hounslow Registered: 16 Mar 2008 Posts: 21 Status: Offline |
Hi, Does anyone know where I put the "orange coloured" power cable approx 5mm in diameter, that runs from the Amplifier to the headunit, I think it switches the Amp on when the headunit powers up.I can see where it goes in my Sony head unit its connected to the blue/white wire, but my pioneer headunit (DEH-P9600mp) does not have a blue/white wire, only a "wired remote input" 3.5mm jack, could this be where it plugs into ???? I'm Confused |
I assume you have a power line from the car battery t the amp ? If not then that's what that wire is for ? The remote turn on is usually a very thin wire (blue) from the head unit with a label showing remote on it ? DO NOT WIRE THE AMP FROM ANY OTHER POWER SOURCE OTHER THAN THE CAR BATTERY AND ALWAYS USE AN IN LINE FUSE |
aaron6
What other wires do you have? As normally its Red-live (battery to amp) Brown-earth (amp to earthing point) Blue (thin)-remote (head unit to amp) Red & white rca cable. (head unit to amp). ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
swiftyboi006
^this ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
roddo
This is the orange wire/cable currently connected to the thin Blue/white wire my Sony Headunit, roddo has attached the following image: |
So have you you got power and earth to the amp as well ? |
roddo
This is where I think it should go on my Pioneer Headunit, but I'm not sure It is I think 3.5mm size, which I think the Orange wire/cable fits in to, what do you think fellas ??? I'm stumped !!! Next stop auto electrician roddo has attached the following image: |
roddo
bigbadbowen wrote: So have you you got power and earth to the amp as well ? [Yes I think so, I had everything installed by an auto electrician, so i'm sure its a proper job] |
I don't think so bud ? The remote turn on is usually a thin wire get a multimeter on the wires from the head unit and find the the 12v signal wire when the head unit is turned on ? Maybe a pic of what has been wired where would help ? |
aaron6
Plug it in and play. If you have fuses in the amp and stereo nothing should blow. But yeah, normally the remote is a thin blue wire. Can you post pictures of all the wires on the head unit?________________________________________ See the sheer power and might of the lesser known burrowing owl. |
footah212
Senior User Location: Paisley Registered: 16 Sep 2010 Posts: 861 Status: Offline |
roddo wrote: This is where I think it should go on my Pioneer Headunit, but I'm not sure It is I think 3.5mm size, which I think the Orange wire/cable fits in to, what do you think fellas ??? I'm stumped !!! Next stop auto electrician Is that plug not for some sort of steering column controller for the headunit? ________________________________________ Phase 2 Blaze GTi6PS3 - Black Ops 2 Engine crane for hire Renfrewshire |
roddo
just spoken to my Auto Electrician who installed my sound system, and that black remote lead is not for my orange amplifier cable, so I'm not gonna risk damaging my I.C.E., I'm taking it to him to sort out.Thanks for everyones in put |
