| Author | Subject: V6 gear box |
yadam
Junior User Location: exter Registered: 15 Oct 2010 Posts: 53 Status: Offline |
Do any other gear boxes fit on the 406 v6 1998 engine |
Why whats the problem? Any ML box would fit. I'd have thought there are quite a few renault boxes that fit too.________________________________________ Nothing to see here |
I believe the V6 has its own bellhousing.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
welshpug! wrote: I believe the V6 has its own bellhousing. f*ck. ________________________________________ Nothing to see here |
indeed, lots of them about though, and I'd imagine the internals from another ML could be swapped.quite strong boxes all told, some 5th gear issues on some IIRC but that may have been the older ME gearbox. whysat? ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
yadam
I don't no much if any thing about gear boxes. What I was hoping is that I could put a diffrent box on to sort out the hydrolic clutch but now I'm thinking could I gt the pedal box from the 406 and weld in has any body heard of this |
Yup that's exactly how you do the conversion bud 406 peddle box welded into a 306 bulk head |
And the stabiliser mount as well |
406 pedal box wont fit directly, its a right old bodge making it fit. I have heard of a hydraulic clutch master being fitted to the 306 pedal, possibly a late berlingo/partner, unfortunately the pedal box is a different shape, the earlier vans ere the same bulkhead but never used a hydraulic clutch. you don't want to use any other gearbox on this engine. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
yadam
Ok have u heard of these http://pitstopusa.com/i-5063193-cnc-swing-mount-clutch-pedal-assembly-w-3-4-master-cylinder.html could I fit this |
I'd just get hold of the original master cylinder and offer it up, save yourself a lot of work trying to figure out what size and stroke MC to use.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
yadam
Ok I just dont understand how that works |
time to start learning faaaast if you're thinking of doing an engine conversion!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
yadam
Yea mate well I gt car, loom , exhaust, ecu ,driveshafts oh and the engine of coarse so far |
My V6 rallye buildV6 wiring diagram download - match up the numbers on the wires... Its a bit of an arse that conversion. ________________________________________ Nothing to see here |
