Author Subject: Crunching/clicking noise
ryans6
I have a horrible noise, when i pull away come of the clutch I get a horrible crunching/clicking noise. It also happens when u let off the accelerator then accelerate you get the crunch.
The wishbones are new, I have changed a drive shaft because of this, droplinks seem to be in good condtion, I have changed the gasket between manifold and cat.
I have been looking for this noie for months and cant find it, it is getting worse and i dont want to keep chucking money at it.
The next thing I am going to investigate is the gear linckages as they have some play in them.
Does anyone have any idears before I waste more money?
Thanks
BLACK 6
Posted 28th Feb 2012 at 18:23
honestly3k
Possibly an engine mount? Unsure
Posted 28th Feb 2012 at 18:24
ryans6
They all look ok tho, I am really puzzled here! This one doing my head in
BLACK 6
Posted 28th Feb 2012 at 18:26
yup, quite likely to be the top engine mount, either the mounting itself or the cradle that's welded to the shell cracked.
Posted 28th Feb 2012 at 18:30
swiftyboi006
Get a long bar like a crow bar n jam it in between the top mount and chassis and see if you can move the engine. This hapend on mine and the engine moved a mile
Black p3 Love
Posted 28th Feb 2012 at 18:40
ryans6
I lost the rear end a while ago and thumped up a curb, started after then really. I shall look tommorow
BLACK 6
Posted 28th Feb 2012 at 18:41
grumpychef
The Rib Man
it happens a lot! like my old blaze. sounds similar.
Formally team BLAZE now Team bianca recuperating from multiple organ failure nicely!
items replaced so far, clutch, cambelt etc, radiator, exhaust, most of front running gear, wish bones, drop links, ball joints, track rod ends, bearings, brakes, calipers, discs, and pads, brake lines, front springs, brake balance compensator thingy, hand brake cable, throttle cable (twice), coil pack, door handle, windscreen, wipers, head lamps several sensors and bulbs Dry .rear beam new throttle cable, new battery. .......... yeah man, team money pit! but shes still rollin!
Posted 28th Feb 2012 at 19:17
I would definitely be looking at the top engine mount cradle. Yes
It sounds like the classic symptoms to me. Sad
Posted 29th Feb 2012 at 09:02
