Author Subject: Spoiler Adhesive?!
martinh
I changed the tailgate on my Rallye recently and the original that was removed was a phase 3 item with holes in the glass to bolt the spoiler on.
The replacement, Although its phase 3 (no black strip on the bottom) doesn't have the holes in the glass to bolt the spoiler on.
What I was intending to do was to grind the studs on the phase 3 spoiler down so it would fit flush against the glass and use some sort of adhesive, tigerseal or similar to attach the phase 3 spoiler.
My question is what's the best adhesive to use for bonding plastic to glass and do you think adhesive on its own will be enough to hold it?!
Thanks
Martin
Posted 26th Feb 2012 at 16:36
mcfc1987
Tiger seal.
Im trying to get an aftermarket spoiler off mine that has been stuck on with the bloody stuff. as long as you don't ever want to remove it then yes its fine lol
Posted 26th Feb 2012 at 17:10
martinh
Okey doke, Thanks for that. Was just a bit dubious about the weight of the spoiler, dont want it flying off and levelling someone!!!
Posted 26th Feb 2012 at 17:17
Phase three spoiler bolts through the frame not the glass ? Phase 2 bolts through the glass Yes do you have a p3 hatch ?
Posted 26th Feb 2012 at 17:31
martinh
Maybe i'm getting confused with spolers then! Definitely a phase 3 hatch, the original was and so is this one but the replacement doesnt have the holes through the glass like the original!
The original spoiler was the thinner one with studs on the underside and the one that came with the replacement is almost double the width that secures to the frame via torx bolts!
Not sure which spoiler is which now!!
Posted 26th Feb 2012 at 18:01
martinh
This is the original spoiler, Is that phase 2 or 3??!!
Posted 26th Feb 2012 at 18:07
Phase 2 is smaller and bolts to the glass phase 3 is bigger and bolts to the frame Thumbs up
martinh
Oh right! I thought it was the other way round! Thanks for clearing that up mate!
Guess the phase 3 one will be fitted then as its the much easier option!! Although its not in the best condition..... off to the parts for sale section!!!
Posted 26th Feb 2012 at 18:09
Phase 2 windows have the rubber seal round the glass as well Thumbs up
Posted 26th Feb 2012 at 18:20
Sand it down then get it painted Thumbs up
Posted 26th Feb 2012 at 18:23
martinh
Yeh thats an option! If someone's got a cheapy for sale then I'll prob go with that option to be honest!!
Posted 26th Feb 2012 at 18:24
Got one in the shed dude as said needs sanding down and painting if interested make me an offer Thumbs up
Posted 26th Feb 2012 at 18:55
