Author Subject: gti6 brake setup?
playboyb
Looking for some gti6 brakes for my xs, wondering what you can use to clean the calipers off? Wire brush? But mainly what people think is the best pad and disc setup? Hoping to get some different views. Thanks
Sam
306 1.8 xs moonstone blue-SOLD
306 gti6 supercharged china blue-SOLD
406 coupe D9 3.0 V6-SOLD
Posted 25th Feb 2012 at 19:03
dan86
Ds2500 pads with standard discs front and back. The xs has 266mm discs and the 6 has 283mm. If you have Lucas calipers you can get the larger gti6 mounting bracket to make them suitable for the larger disc.
Posted 25th Feb 2012 at 19:59
playboyb
Was just going to get gti6 calipers and new discs and pads, want something that won't fade, fast road/track use. Gti6 calipers will bolt straight on surely?
Posted 25th Feb 2012 at 20:04
dan86
Ferodo ds2500 pads are very good at taking serious heat. They don't bite very hard when cold but the more heat you put in them the better they get. They have very good modulation. I've found that standard discs are up to the job if you look after them; get them up to temp gently and cool them down before parking up.
I just thought that if you already have the Lucas caliper then you could save a few quid and only buy the mounting brackets. If you have Bosch or girling calipers then yes you will need both calipers and brackets (yoke's) from a gti6 to make a 283mm disc fit.
Also if you buy Ds2500 pads you should order them for an Alfa Romeo as they sweep the entire disc without leaving a lip. I'm not sure which model Alfa; I'm sure someone on here will know?
Posted 25th Feb 2012 at 20:30
playboyb
Ok nice one mate, appreciate the help. So some alpha discs fit the 6 caliper then?
Posted 25th Feb 2012 at 20:34
Alfa pads will fit the caliper, not the discs mate. Wink
Posted 26th Feb 2012 at 07:47
playboyb
And there better than pug ones?
Posted 26th Feb 2012 at 07:49
Only because as previously mentioned they sweep the whole area of the disc and don't leave a lip. Wink
Posted 26th Feb 2012 at 08:16
playboyb
Ok nice one, ill have a look around Smile top admin stan!
Posted 26th Feb 2012 at 08:27
No problem. Thumbs up
You could just go on eBay and find a complete setup straight off a donor car and then fit the lot, rather than worrying about which bits you need to buy to make it all work.
Posted 26th Feb 2012 at 08:31
playboyb
Yeah I had a look and there's a couple floating around as big brake setup for a saxo/106. Bless them
Posted 26th Feb 2012 at 08:32
Its probably the best way to go so you know you have everything needed to fit when you come to do it. Wink
Posted 26th Feb 2012 at 08:35
playboyb
Its all good grandpa stilly does the work on my car, he won't hesitate to tell me I'm missing something
Posted 26th Feb 2012 at 08:36
playboyb wrote:
grandpa stilly
Laugh my ass off Laugh my ass off
Posted 26th Feb 2012 at 09:12
atterz
What model alfa pads are needed?
owain wrote:
Posted 26th Feb 2012 at 11:43
