Author Subject: Catcams
atterz
Clicky <<< Cant linky because im st00pid Smile
Just wondering if anyone has experiance with these cams and if i need to be extremely cautious if i do have a skimmed head. Seem like a great modification when mapped in. Are pocketed pistons needed?
Cheers all.
owain wrote:
Posted 25th Feb 2012 at 18:46
Clicky
Posted 25th Feb 2012 at 19:00
I am not 100%, but I don't think you need pocketed pistons for the use of these cams as they spend a lot of time in the advert talking about adding these to enhance the "standard" performance.
Doesn't mention you will need to rebuild the engine with different pistons to be able to take advantage of such items. No
Posted 25th Feb 2012 at 19:03
I'd go Newmans or piper, chatted to Sandy and he has not so good experiences of catcams.
Posted 25th Feb 2012 at 19:36
atterz
Cheers Stan thats what i wanted to hear about not ripping the head off!
Mei, what piper or newmans cams should i be looking at for the same increase? More power and torque with no expense of driveability floats my boat on my less than awesome wage!
Posted 25th Feb 2012 at 19:48
PH2's work fine, no idea of gains as I never got a chance to have mine mapped, but it ran on stock ecu.
Piper BP270H will also go in a stock engine, Kent PT's I wouldnt use personally as they have a tad too much lift @ TDC.
Peter Taylor does some regrinds, if you can get a spare set and get on 205gtidrivers sharpish there's a group buy being arranged.
Posted 25th Feb 2012 at 19:52
atterz
Similar sort of gains?
Posted 25th Feb 2012 at 20:10
Not seen many published figures or project threads, but Peter's would likely to be some of the best given he's done testing of his own profiles.
Posted 25th Feb 2012 at 23:24
atterz
Cheers mate Smile Will look in to it!
Posted 26th Feb 2012 at 10:45
mabgti
NV motors
Regrinds are never gonna in tolerance to the thousanths on a new cam?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 26th Feb 2012 at 13:38
jammapic
For me it would be CatCams + Mapped at RSTuning... I know they give a proven result! Razz
JP
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 26th Feb 2012 at 14:44
they may well do, but after my chat with sandy I wouldn't use them.
Posted 26th Feb 2012 at 15:31
info@pug1off.com
I have to say that Catcams are one of the best power products on the market. Before we swapped over to Cat for our race engines we were struggling to make more than 255bhp, with Cat we instantly got to 302.
They are supplied with a full data sheet, more info than any other manufacturer and advice on what additional components are required ie. piston cut-outs, follower type, and detailed timing data. If you have a profile number for these cams I can advise on the fitment.
N/A XU10J4RS = 302.1 bhp / 184.2 lb.ft
Turbo XU10J4RS = 500.2 bhp / 443 lb.ft
USC 2011 Double Class winners
N/A FWD 0-60 winners at TRAX 2011
Developers, stockists and installers of superior upgrades for the Peugeot 306 GTi6 & Rallye, including:-
*NEW!!!!! 4.8:1 final drive for BE3/6
*BBM Group N engine mounts
*Cat Cams and vernier pulleys
*Emerald ECU's
*Jenvey throttle bodies
*Uprated gear linkages and short shifts
*Quaife & Tran-X LSD's for BE3/6
*Tar-Ox brake discs and Ferodo DS2500 pads
*Solid rear beam mounts
*21-25mm torsion bars
*25mm rear anti roll bars
Posted 28th Feb 2012 at 22:03
info@pug1off.com
Just followed the link, the "106" profile is great with a remap and the latest results can be seen on our blog below dated 10/12/11. Timing is 112/112 and as long as the timing is carried out by a competant engine builder nothing will go wrong. If you use the standard timing marks it probably will. Often Cat will push the limits of a Cam such as this to get the valve to piston clearance fairly close optimizing performance, but correct timing is essential.
http://www.pug1off.com/peugeot_citroen_specialists_brackley/blog/
Hope this helps.
*Emerald ECU's
Posted 28th Feb 2012 at 22:17
