Author Subject: BREMBO'S
i8er_4hed
hi, i have 4 pot brembo's with discs off 406 v6 coupe, would like to know if it all bolts straights on. to my gti6? got braided hoses too. cheers Thumbs up
Posted 21st Feb 2012 at 23:41
birk
You need to use xantia 288mm disks to use them on a 306, lots of squealing :
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 21st Feb 2012 at 23:53
techdw
Check out the brakes section mate, loads of information in there when I was looking around before.
Posted 22nd Feb 2012 at 08:56
russbez
as birk said
they fit straight on chances are you will need at least 16" alloys some 15"s fit
288mm discs
and a set of ear defenders Big grin
My Rallye project thread
Posted 22nd Feb 2012 at 09:15
There are ways to stop them squealing but you'll have to search. Hoses need sorting too.
Posted 22nd Feb 2012 at 09:52
You need Tarox g88 discs to stop the squealing I believe.
Might be better off going for ashes kit. or if like me you wnat to be different get the brakes for a 807 v6 (Magnesium) and adapters.
Posted 22nd Feb 2012 at 11:08
i8er_4hed
Cheers peeps, thts good cos im sure we've got the xantia brake discs sitting on the shelf at work 'old stock' as for squealing might try using offset shims behind the pads.. also cars sitting on 17s so clearance should be cool..
Posted 22nd Feb 2012 at 19:57
daicarvideoguy
Just so we are absolutely clear, as about to hand over some cash for 406 Brembo's. if I use 288 disks will 15 cyclones fit? Or do I need to buy spacers ?
I don't want to be putting the car back together next Sunday and find the wheels will not fit on & then be stuck with car on axle stands.
I have standard 15 inch cyclones.
Sorry to hi jack the thread but it's hard to get a definate answer.
Cheers Dai
Xbox Live: DaicarvideoGuy, Forza 4
Posted 27th Feb 2012 at 17:10
stu
AFAIK, Cyclones will fit but you will need some chunky spacers to get enough clearance. Not an ideal solution IMO.
Better to get wheels in the correct fitment with enough clearance.
I'd avoid spacers at all costs, just my opinion, but I've never trusted them since one tried to remove itself from my car on the motorway. Never used them since.
Posted 27th Feb 2012 at 17:14
Deffo need spacers with cyclones. Tarox g88 stop the squealing but are 200 plus a set.
Posted 27th Feb 2012 at 17:21
scottycollard
Does anyone know what brake hoses to use when fitting brembo calipers cheers
Posted 5th Apr 2012 at 23:24
PM mrSwampy
Posted 5th Apr 2012 at 23:54
midlife
You can use STD 306 hoses if you get extensions from Phillipm
Cool
Team 330™Cool
Team "no front end or engine"
Posted 6th Apr 2012 at 00:15
Cool
This is true, although if you're upgrading the brake system it would be wise to upgrade the hoses too. I have a Goodridge kit and can't fault them. Thumbs up
Posted 6th Apr 2012 at 07:21
scottycollard
Right ok I am thinking of getting some braided hose's but I work next door to exact engineering who make them just need to know what pattern i need so they could make them. What goodridge set have u got stan
Posted 6th Apr 2012 at 09:55
standard length hose then a section of hard pipe like this
or just buy this
http://www.ebay.co.uk/itm/Peugeot-306-GTi-6-Rallye-Brembo-4-Pot-Braded-Frt-Brake-Pipes-/350516917821?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item519c6fb63d
Posted 6th Apr 2012 at 10:22
russbez
that looks like its been jublied on?
Posted 6th Apr 2012 at 14:03
what has?
Posted 6th Apr 2012 at 14:11
eddy_gti6
There is another way to stop the brakes squeeling Wizard
Posted 7th Apr 2012 at 03:04
yeah, dont use them LOL
Posted 7th Apr 2012 at 09:54
LOL
No squeeling whatsoever if you go for a big brake kit with the Brembos, although it does cost quite a bit. Yes
Posted 7th Apr 2012 at 10:52
midlife
The STD 406 setup has a length of solid pipe.
Cool
Team 330™Cool
Posted 7th Apr 2012 at 11:03
