displaying posts 26 to 50 of 55
Pages (3): 1 [2] 3
Author Subject: colin satchell inlet
Sounds like you made some decents gain there, nice one! Thumbs up
Posted 28th Mar 2012 at 10:46
rallyeash
whats your engine spec, sounds good figures though. don't have a torque curve for mine, wouldnt grip in the rollers!
309 3dr K20 Type R
Posted 28th Mar 2012 at 11:53
dav1
Weber throttle bodies ,omega 87 mm pistons, Newman ph4 cams, omex 500, arp bolts, an Satchell inlet. Don't think mine will have the lower down grunt that yours has thoe but its a self build. some ppl on here were tellin me not to do it my self. Think I saved some money thoe time will tell if it lasts. Should do thoe as plenty of valve clearance an upradted bolts . It's just probably the rods on the limit now .
230bhp 205 gti6
Posted 28th Mar 2012 at 12:01
davewagon
2.1 sounds an interesting alternative to s/c route?
What's required and the sort of costs involved in doing this, and how hard is it to change over the necessary bits yourself?
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 28th Mar 2012 at 13:54
rallyeash
sounds good... are you just running standard 87mm gti6 crank?
davewagon it wont be a 2.1 if it isnt 88mm diesel crank
309 3dr K20 Type R
dav1
Yeah std crank
230bhp 205 gti6
Posted 28th Mar 2012 at 13:56
davewagon
Okay my bad, so what is meant by 87mm pistons?
not changing displacement size no?
Posted 28th Mar 2012 at 13:59
dav1
Does increase cc little bit but not to 2.1
230bhp 205 gti6
Posted 28th Mar 2012 at 14:01
davewagon
Ah cool
So what is involved then, swap out inlet manifold for bodies, swap over inlet for CS one and while at it, change out pistons and cams?
Then off for remap, starting to sound expensive now?
Posted 28th Mar 2012 at 14:04
Post #35
I know that putting 86.5mm pistons in instead of the std 86mm ones takes the CC to around 2040cc as this is what I am running. Yes
Posted 28th Mar 2012 at 14:24
davewagon
Post #36
Are we talking about piston width here? Does that require any machining of the engine?
Posted 28th Mar 2012 at 14:26
dav1
Post #37
Can be expensive but if you shop around then you can get deals. I got a smashed up 205 gti6 on the bodies, omex and the rest std 800 then bought other stuff for cash an forums. Did pay full price for some stuff plus I built engine me self but was quiet easy .
230bhp 205 gti6
Posted 28th Mar 2012 at 14:29
dav1
Post #38
Yes boring out
230bhp 205 gti6
Posted 28th Mar 2012 at 14:30
davewagon
Post #39
Right, so that's a whole engine out, and pulled apart job then yeas?
Posted 28th Mar 2012 at 14:33
rallyeash
Post #40
yes
Complete engine strip down, block bored to correct size and complete rebuild with your choosen spec.
309 3dr K20 Type R
Posted 28th Mar 2012 at 15:01
davewagon
Post #41
That's killed that idea quickly then LOL
Posted 28th Mar 2012 at 15:54
ryangti6
Post #42
86.5mm bore should take your CC to 2022, you would need 87mm to get 2040 I think.
Also dont know if that was a typo by Ash but standard crank is 86mm stroke as far as I know
Ryan
Posted 28th Mar 2012 at 17:47
Post #43
Ryan - You're spot on, I messed that right up, so long since I did it. LOL
Yes, mine is 2022cc and yes the standard crank does give a stroke of 86mm, because the standard pistons are 86mm and therefore makes the '6' engine as standard a "square" engine. Yes
Posted 28th Mar 2012 at 19:43
Post #44
So basically your looking at 3k plus for a 2.1?
What power /torque do they make as standard (i.e without crazy cams and tbs)
Posted 29th Mar 2012 at 01:04
Post #45
hard to say specifically, but the best example I know of was 240 bhp 186 lbft, petert inlet cam, colin satchells throttle body inlet, standard RFY rods, 92mm crank, 87mm bore, standard head, forged pistons.
don't know anyone running them on standard t/b, given a stock engine makes around 185-190 on bodies, I'd say its a pretty good way of a very punchy engine without all the complications of fitting lots of weight and faffage of the supercharger kit.
Posted 29th Mar 2012 at 10:59
ryangti6
Post #46
92mm stroke and 87 mm bore would round up to a 2.2 though not a 2.1, with 87mm bore you only need a 88mm stroke crank to get a 2.1.
GTIsid (Tony) used to run a 2.1 bottom end on a standard inlet in his old diablo iirc, pretty sure he was making fairly good torque and ~190bhp.
Ryan
Posted 29th Mar 2012 at 11:59
Post #47
yeah, but if you're going to bore it out an buy pistons, why the hell wouldn't you not go 92mm LOL
Posted 29th Mar 2012 at 12:07
ryangti6
Post #48
I was always under the impression that a long stroke engine will give you better torque but wont want to rev aswell so personally I'd go for the closer to square option and have a better all round engine.
That said the power and torque figures are very impressive on that engine you have mentioned, any idea where in the rev range it makes that power and torque
Ryan
Posted 29th Mar 2012 at 12:22
Post #49
I'll see if I can find it, I don't think the rules are that simple or hard fixed, the F4R renault lump for example is 92x83 and doesn't quite match up to the 86 square pug XU's, and is a little behind the EW 2.0 85 bore x 88 stroke.
K20A is a good example, 86mm square, 8k+ redline, over 11-1 compression as standard.
Posted 29th Mar 2012 at 12:31
atterz
Post #50
A square boosted engine is definatly the way forward, a good revvy engine with torque. I dare say that is why the WRC cars used a 1.8.
owain wrote:
Posted 1st Apr 2012 at 13:49
Pages (3): 1 [2] 3
