Author Subject: Discs and Pads All Round
sergioiacobucci
Hi,
I am getting some vibration under braking so I want to change all round. Wondering if anyone had some discs and pads lying around - happy to use part used as long as there is a bit of life still in them
Cheers!
Phase 1 silver track car
335i daily
Posted 11th Feb 2012 at 14:44
Rich E Forum Admin
Buy new then. You may find exactly the same problems with a used set.
Posted 11th Feb 2012 at 14:51
sergioiacobucci
Very good point! Thanks - I am just debating whether I should go cheap and they are all the same or buy mid-range discs and pads. I am on a student budget at the moment!
335i daily
Posted 11th Feb 2012 at 14:54
gilesy
GSF or buypartsby
Posted 11th Feb 2012 at 15:01
sergioiacobucci
gilesy wrote:
GSF or buypartsby
I am looking at GSF how do I know what brand the discs are....or are they established as doing good quality stuff?
335i daily
Posted 11th Feb 2012 at 15:10
wilyoldave
http://www.ebay.co.uk/itm/330414803646?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Get them - were spot on on my old Rallye
Dave
No more peugeots Sad
Snap - no more RS clioSad
Now Ph1 RS clio Smile
Posted 11th Feb 2012 at 15:29
Batesy86
Seem to be lots on eBay, cheap discs with some Mintex pads though and you can't go wrong!
Posted 11th Feb 2012 at 15:35
webster
I think it's like £100 to buy disks and pads all round new mate.
cress87 wrote:
I'm stopped for speeding on a daily basis but now the police are aware that I live for the 306 they dare not interfere, just sit in their cars quaking as I drive past.
Posted 11th Feb 2012 at 15:59
honestly3k
gilesy wrote:
GSF or buypartsby
GSF used to do brembo, but no longer. The premium brand they use now is a brand called 'Bendix' which are supposedly good. Google them. You wouldnt want to be using the lower budget branded discs or pads on a 6 really imo. So go Bendix or go with a different motor factor for an alternative.
I used Pagid from ECP which i dont think are bad but i think mine warped quickly after installation as i had a slider pin loosely fitted Doh
Since tightening that up the shaking has dramatically reduced but is still there....maybe a result of the disc locating screws rounding off so disc is loose slightly because of that but thats my next port of call before new discs again
Posted 11th Feb 2012 at 16:05
sergioiacobucci
Thanks for all the help, I think ill be going for the Mintex ones on eBay
Cheers!
335i daily
Posted 11th Feb 2012 at 16:37
honestly3k
I thought Mintex had a reputation for brake squeal?! I hope im wrong and maybe ive just been looking into brakes too much LOL
Good luck, just realised your from Beaconsfield, i drive through there quite often but never seen you Hmm
Posted 11th Feb 2012 at 16:46
wilyoldave
Thumbs up
gilesy
If your brake disc is loose then I suggest you tighten up your wheel bolts before your wheel falls off...
Posted 11th Feb 2012 at 16:57
you can leave those screws off totally, it wont cause this, however if the disc does wobble, do as suggested above and tighten up your wheel bolts LOL
Posted 11th Feb 2012 at 16:59
honestly3k
I thought that too but was advised it would still be preferable to not having them in, to be fair its a pain when said disc moves when you take the wheel off so for that reason alone i will get them replaced.
Just seems strange that the car ONLY judders under braking now from 70mph down to 40mph then wont judder atall from 40mph to stationary since the sliding pin was tightened up. Before it was tightened it would judder at all speeds
Posted 11th Feb 2012 at 18:18
Vibrating from 70 to 40 under breaking is shagged discs or you didn't clean the hubs up properly making the disc not seat correctly thus not running true
Posted 11th Feb 2012 at 18:26
honestly3k
Thanks, they make up part of an ever growing list of things to do on the car in the not too distant future LOL Thumbs up
Posted 11th Feb 2012 at 18:35
I always sand the disc surface on the hub as its generally got rust on it always a good idea to grease the sliders as well to ensure they are not sticking. A sticky slider will over heat the disc and warp it Thumbs up
I have also found new discs and pads on the front with old sh1te on the back upsets the brake balance? Might just be me but a dam good clean and grease all round with new discs and pads Is just the ticket Yes
Posted 11th Feb 2012 at 18:48
sergioiacobucci
Well I go to uni in Bath so I am not there all the time!
335i daily
Posted 14th Feb 2012 at 00:22
