Looking up inside the footwell,rain water drips down from the plastic tray that forms the top cover of the footwell. The drip originates from where the tray/cover contacts the carpet at the front of the footwell to the left hand side of the footwell, pretty much in the corner.
I think a seam is leaking inside the front scuttle under the bonnet passenger side,(essentally this is a gutter draining into the drain hole left side which is clear) but the heating suction duct is in the way. looking at it it means removing the plastic tray at the bottom of the windscreen (removing wiper arms first) but I notice there are a number of those awfull push type plastic clips which seem to never go back.
My question: anyone had this problem if so is there an easy quick fix without removing the plastic windscreen tray & heater inlet duct?
sampsonm
it works tho i wouldnt recommend doing it alot tho might lose old eye sight
