Author Subject: Diagnose this
hsustyle
Running rich
Boggy revs
Jerks and attempts to cut out at around3-4k revs (usually when warm)
Uses a lot of fuel
Not as much of a punch when I hit the loud pedal.
Lambda sensor? I have a spare one but cant get the current one off.
I drove it for a mile or two with the lambda sensor unplugged and had the same issues.
Could it be a sensor? Dirty/ clogged injectors?
Earthing?
Beef Beyond Belief
Posted 6th Feb 2012 at 17:31
mrdeey
how do you no its running rich ? other than that sounds like a faulty coil pack or packs
now new booted , boosted and flying again!
Posted 6th Feb 2012 at 17:33
Coolant Temp Sensor (the green one on the thermostat housing) could be goosed. This will give you the symptoms you describe, especially when warm. Yes
Posted 6th Feb 2012 at 17:34
hsustyle
It is according to my mechanic mate. Also there are random flatsports/ hesitation in the higher revs (4.5k+ ) and a slight 'Pop' when it goes back to pulling hard.
Beef Beyond Belief
Posted 6th Feb 2012 at 17:41
As above my vote is either CTS or MAP sensor.
Posted 6th Feb 2012 at 17:44
mechanical_repairs
Is this the car you have just had the head repaired on? If so I would say its the lambda and it will have been contaminated in coolant when it was stripped.
Carl
Posted 8th Feb 2012 at 20:20
He hasn't had it stripped down yet Carl, although I too think the lambda is a very good culprit. Yes
Posted 9th Feb 2012 at 07:28
pop the plugs out and stick up a pic Smile
Posted 9th Feb 2012 at 11:18
sharvey44
MAP sensor
Ph2.5 Nile - Slowly trying to de-East London it and restore to former glory...
Built on the 9 Febuary 1999 - Tuesday's car..is full of pace? Wink
Currently looking slightly molested due to some c*nt trying to get into it.. Sad
According to the forum Social Worker, because I work in IT, I am socially retarted..
Posted 9th Feb 2012 at 11:34
swiftyboi006
Lambda at a guess
Black p3 Love
Posted 9th Feb 2012 at 15:51
hsustyle
It only starts on 3cylinders and there Is a distinctive smell of petrol from the exhaust. Then clears after a minute or so.
My mechanic said its HG. Lots of steam out the exhaust too.
Beef Beyond Belief
Posted 10th Feb 2012 at 10:44
Sounds quite likely, the fuel would usually be from the non-firing cylinder plus the lambda being confused to feck by the coolant, possibly dead by now which is quite common with hg fails.
Posted 10th Feb 2012 at 10:46
hsustyle
I'll pm you shortly to see if and when you can get the Hg done on it.
Beef Beyond Belief
Posted 10th Feb 2012 at 11:38
