Author Subject: COOLING FANS - HELP PLEASE!!
mjkent
Fans not coming on at 97 degrees or 107 degrees and I get no warning light on the dash when it gets hot.
Have been through most things in other threads but this is where im at now....
Remove the brown plug from the temp sensor and only the drivers side fan comes on at full speed. (the sensor has already been changed).
Removed both fan motors and both work ok when tested.
Swapped the fan relays and still the same although it feels like (when I put my thumb on them) they click in.
Am now thinking it has to be the Bitron unit?? especially as Im not getting any warning lights either.
Also, have removed and cleaned up any connections related to the fans although they were all in a good condition.
Any help, much appreciated!!!
Posted 28th Jan 2012 at 17:25
Pay membership and they will automatically work Tee hee
Soon to be moved to the correct section too.
Posted 28th Jan 2012 at 17:35
af1-gti
this is what I did
Rich E wrote:
With the 306 Rallye the goal wasn't to make a purer or more focussed car. It was to make a cheaper car, and then cynically use Peugeot's motorsport heritage to make it appeal to enthusiasts.
peetypug
Will he be able to see that if he isn't a paid up member?
Cherry rallye - DOB Thursday 29/04/1999
Team Rallye - the leaner, meaner, better looking sister of the GTI6 Big grin
roland rat wrote:
You sir either live for the 6 or have a mental retardation to still be repairing this!
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fecking temperamental.
Posted 28th Jan 2012 at 17:42
There is a small box of tricks behind theassenger side wheel arch liner that is probably fecked they get battered with water and all sorts of sh1t prob needs changing Thumbs up
Bitron unit I think it's called
mjkent
My bad....
Just joined forum. Didn't read the bit about paying for membership. Will join now. Thumbs up
Posted 28th Jan 2012 at 17:46
