Author Subject: Help plssss=[ Wheel touching back side cover!
metbianco92
HI i recently added new alloy wheels to my 306 . The rims are 15 inch and the problem is that the back tyre is touching the the inside of the arch:/ all i need is some kind of spacer which would make a little more space between the tyre and the inside. I'm scared that the tire is going to damage it self as it is making a funny noise when i drive.=[ any help pls?
matthew
Posted 27th Jan 2012 at 22:28
mattgti6phase2
What is the current off set??
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 27th Jan 2012 at 22:53
SteviePut
It's currently not right Wink
Posted 27th Jan 2012 at 22:56
metbianco92
what do you mean off set?
matthew
Like what Andy Murray has.
Posted 27th Jan 2012 at 23:21
The offset of the wheel is incorrect for the car it's all about the et number ? This number should be on the wheel somewhere pug figment is usually et18 I suspect yours is prob et 30 or something ?
Yes
Posted 27th Jan 2012 at 23:28
scotzman
He had 3 off sets.
Posted 27th Jan 2012 at 23:29
ryangti6
Is it like it on both sides?
If it is its going to be the wheels as said, if it's only on one side its more likely your rear beam is f*cked.
Ryan
Posted 27th Jan 2012 at 23:52
chrisd306
Is it fouling on metal or plastic? I had to remove rear plastic inner arch as all my track wheels rubbed on them
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 27th Jan 2012 at 23:55
jimmyhackers
i had to get spacers for my 205 1.9 gti alloys to fit on my 306's.
ive had bad experience with spacers before. my 1.4 threw a wheel at 60 on spaghetti junction. i was using 25mm spacers/adaptors that used 4 bolts to attach the spacer and 4 nuts to attach the wheel to the spacer.
my advice. buy hubcentric spacers and use extended bolts. check thier condition daily
do not buy wheel adaptors, anything that requires plastic spigot rings. or non-hubcentric spacers. do not try to get away with original length bolts.
Posted 30th Jan 2012 at 17:06
