Author Subject: Airbag light removal
braymond
I want to take the bulb out, and if memory serves its possible to, for want of a better expression, have a little reach around and remove it.
Can anyone tell me what i do and dont need to undo/take off to get enough space to get a hand in there??
Ta
Rallye-R
Nurburgring article
Posted 26th Jan 2012 at 14:04
wheel off, steering column covers off, cluster surround off, pull out cluster, unlyg multiplugs, flip over pull out bulb.
you removed the airbags?
Posted 26th Jan 2012 at 16:34
braymond
Its a rallye, so only 1 airbag, but yes, it went with the wheel - I'm with with fixed buckets (so no pre-tension circuit) and harnesses now.
Rallye-R
Nurburgring article
Posted 26th Jan 2012 at 16:42
might as well bin the airbag ecu too then Smile
Posted 26th Jan 2012 at 16:51
braymond
DISCUSS! i like the sound of this...
Rallye-R
Nurburgring article
Posted 26th Jan 2012 at 17:01
monkeyman
You can get the instrument panel out with just removing the top steering column cover 2 x 15 Torx, and the instrument surround 2 x 10 Torx, 2 x 15 Torx. The panel has 3 x 15T holding it on and two leads/cables which have a hinge/latch holding them on.
Wiggle it past the steering wheel to get at the bulbs.
Forum Search Clicky
Posted 27th Jan 2012 at 13:40
anth
Take the center console out and the bit directly under the dash if that makes sense where the ash tray etc is, the ECU is there.
Posted 27th Jan 2012 at 17:03
2 x 20 Torx. Yes
Posted 10th Feb 2012 at 21:08
mechanical_repairs
Just put a 2.7 ohms resister in the airbag plug, that way the light will come on and go off as normal, resister will cost you 16p from maplin or the likes.
Carl
Posted 12th Feb 2012 at 20:34
russbez
Carl
this is pretty much what i done, i have no airbag now
although i used a 1.8ohm resistor, got the receipt from Maplin here 19p each Yes
had to use one on wiring under passenger seat too for some reason Yes
My Rallye project thread
Posted 13th Feb 2012 at 10:35
russbez
i wasnt sure about doing this
wont effect any other part of car then?
had the Rallye in bits the other week, guess i should of tossed out the whole wiring and airbag controller thing??
Posted 13th Feb 2012 at 10:38
nope, the 306's system is pretty much standalone so you can bin the whole lot if you aren't using any components.
Shouldn't be an MOT issues as its been adapted for a specific purpose, i.e race car rally car etc.
Posted 13th Feb 2012 at 11:02
russbez
Again Smile
Posted 13th Feb 2012 at 12:07
chrisd306
How does this work for the new mot laws that are coming into force? Think it's going to be a fail for airbag and engine management lights being on, not 100% sure tho
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 14th Feb 2012 at 00:45
braymond
The airbag light will be a fail, hence my interest.
Rallye-R
Nurburgring article
Posted 14th Feb 2012 at 11:13
not if the airbag isn't there Wink
Posted 14th Feb 2012 at 11:47
This is confirmed?
I have removed all airbags and ECUs from mine and I have the airbag light on constant (See avatar pic Laugh)
Not an MOT fail if I remove the bulb?
Smile
Posted 14th Feb 2012 at 13:06
looking at the manual there doesn't seem to be a clause for adapted vehicles like there is with seats and a few other bits Hmm
this needs a call to VOSA I think
given the airbags are not present I would remove the bulb indeed, but you might be pulled up for not having any airbags...
Posted 14th Feb 2012 at 13:20
Cheers mate, will go ahead and remove the bulb.
Im sure I can explain to the friendly MOT tester that it has no airbags and instead has buckets/harnasses/rollcage for safety.. should be ok.
Posted 14th Feb 2012 at 13:22
indeed, airbags with harnesses is quite pointless LOL
Posted 14th Feb 2012 at 13:28
chrisd306
I mind looking at the shite that came in from vosa but didn't take much notice but I'm sure if it's ment to have it it should have it, not to sure that's why I asked, loads of new things came into force as if 16th if last month and more to come
& Audi Q5 S Line
Posted 14th Feb 2012 at 13:31
