Author Subject: bigger injectors
JWP EFi
Turbo Legend!
this quiery is on behalf of a mate with a 205 8 v turbo...
over the last wee while we have fitted a t28 compressor wheel and housing to the TB25 turbo, fooled the signal
back to the map sensor(via lots of p*ssing about with various resistors), therefore we have managed to lift
the point at which fuel cut comes in, we now need a bigger set of injectors...
im willing to loan him a set of 330cc/min injectors, question is is the bosch 3.2 ecu able enough to adapt to these??
tempted to just fit them and see what happens
has anyone ever done anything like this with the turbo 8 valver?
Posted 25th Jan 2012 at 20:06
nope, wont work.
it has been done, but not with the original ecu.
Posted 25th Jan 2012 at 22:54
rich_w
Why don't you just get a beskpoke re-map and do it properly?
That's the only way you'll get it running right with bigger injectors.
Contact Details:
07732 822546
Posted 26th Jan 2012 at 17:27
No point doing this shit by halves
Posted 26th Jan 2012 at 18:18
JWP EFi
Turbo Legend!
ok chaps small update. we tried this earlier today and she wasnt happy at all!
started up first time, then stopped pretty much straight away, played about with the fuel pressure, eventually got it
going but drove horrible. decided to plug it in to see what codes came up, Codes 31 & 32, mixture control bank 1
and mixture control bank 2, funnily enough the MIL didnt come on! FAIL!!
next question, who can do custom remaps for these other than dastek?
btw, i'm quite impressed with how adaptive the ecu is so far, XSi cam, bigger compressor, before we did the turbo mod
the chap that ran it on the rollers said fueling was spot on, but needed more boost
Posted 26th Jan 2012 at 19:14
JWP EFi
Turbo Legend!
what about a piggy back unit? apexi or something similar
Posted 26th Jan 2012 at 20:33
fatlapit
put a proper ecu on it???
Posted 26th Jan 2012 at 22:25
what that man said, or go and see chipwzards.
Posted 26th Jan 2012 at 22:29
