Thanks!
If you aint first, your last!
| Author | Subject: Clutch asssit spring. |
spitfire
Regular Location: Leighton Buzzard Registered: 30 Apr 2009 Posts: 365 Status: Offline |
I am after a clutch assist spring that goes on the side of the clutch pedal if someone can help?Thanks! ________________________________________ If you aint first, your last! |
IIRC there was a Tech bulletin for dealers to remove them ![]() if you really want the spring its £6 odd from a dealer. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
gota6again
Seasoned Pro Location: Gone Registered: 18 Jan 2009 Posts: 1,595 Status: Offline |
Both my 6's had the spring removed and the clutch peddle was much smoother, leave it off bud |
Rich E
They make a worn clutch and/or cable feel worse, but a new clutch & cable, fitted with new fork bushes feels much better with the spring than without.________________________________________ Rich |
spitfire
Ah ok, will do. Thanks for the heads up!________________________________________ If you aint first, your last! |
