Beef Beyond Belief
| Author | Subject: Stalling when coasting in neutral |
hsustyle
Seasoned Pro Location: High Hurstwood Registered: 08 Nov 2011 Posts: 1,037 Status: Offline |
I just did a coolant drain and flush because the old coolant looked a bit dirty. Flushed the system properly and bled well.no bubbles or air etc.doesn't go near 90c. Went for a drive,temp stays down nicely,levels fine etc. This afternoon I popped 2miles down the road and the engine stalled when i approached a junction in neutral. Revs died. It fires up fine,sounds and drives fine and the temp and coolant is fine.it did it again just now when i went to park up. Any ideas? It didn't do this before I decided to drain coolant.________________________________________ Beef Beyond Belief |
hsustyle
Also there is hesitation in the lower revs when i put my foot down.What sensor could cause that? Tps? ________________________________________ Beef Beyond Belief |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
likely to be that i think________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
idle valve.does your speedo work? most things can be tested with a multimeter though, check the faq ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
hsustyle
welshpug! wrote: idle valve. does your speedo work? most things can be tested with a multimeter though, check the faq I've unplugged and replugged icv,Tps and map sensor and it still does it.speedo works fine. ________________________________________ Beef Beyond Belief |
that wont fix a worn/damaged item :________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
hsustyle
Shhhh![]() ________________________________________ Beef Beyond Belief |
aaron6
Try cleaning the icv. That often fixes the stalling issues. If not, you'll have to but another I reckon. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
stan_306gti6
As others have said, ICV clean is the first thing to do.If this doesn't cure it then you will need to buy new. Keep an eye on the accelerating from low RPM, as thats a typical lambda fault. If this symptom continues, keep a check on how much fuel your getting through. If it seems excessive, then your lambda will need changing. But hopefully for now, an ICV clean should see you right. ![]() Stan. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
hsustyle
Cheers Stan. I'll keep an eye on it over the next few days.________________________________________ Beef Beyond Belief |
hsustyle
Ok i have cleaned Icv, Tps and map sensor and ir still jumps to 2k revs when I start it up.instantly drops to 900rpm again. There is a hesitation between 1k-2800 revs and sometimes just cuts out. Pulls hard and smooth after 3k revs. Ahhh soo annoying. ________________________________________ Beef Beyond Belief |
stan_306gti6
hsustyle wrote: Ok i have cleaned Icv, Tps and map sensor and ir still jumps to 2k revs when I start it up.instantly drops to 900rpm again. There is a hesitation between 1k-2800 revs and sometimes just cuts out. Pulls hard and smooth after 3k revs. Ahhh soo annoying. That is classic lambda fault symptoms. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
hsustyle
Good to know.I'll be after a new one then! Ah well,could have been worst.________________________________________ Beef Beyond Belief |
