Author Subject: fuel pump not priming
panks blaze
my car cut out whilst driving home last night.got it home to try and sort it out and its not priming when i turn the ignition on.is there a fuse or relay that could have gone?
black and gold
Posted 21st Jan 2012 at 14:47
does it run fine? if so dont worry about it.
panks blaze
it did run fine and just cut out.cant hear the fuel pump priming though.
black and gold
Posted 21st Jan 2012 at 14:50
panks blaze
just reading the FAQ on fuel pump relay so ill give that a go.
black and gold
Posted 21st Jan 2012 at 14:54
Just had the exact same problem with mine Sad
Posted 21st Jan 2012 at 15:34
panks blaze
theres power there but the pump isn't priming up.is there a possibility its the ecu?if so do i need a new ecu or can i get the same one unlocked?
black and gold
Posted 22nd Jan 2012 at 09:56
russbez
since everything has been working fine for a while id try another fuel pump relay, they sit behind battery
i would doubt it being the ecu mate
My Rallye project thread
Posted 23rd Jan 2012 at 14:44
Fuel pump relay is the first point of call. These are quite a common failure. Held in by one 8mm nut behind the battery box.
Posted 23rd Jan 2012 at 15:16
I had the exact same issues about a year ago and I ended up replacing relay and pump, then turned out to be the immobiliser at fault.
Stan, could it be possible that going over a bump could break the relay? As I hot a bump in the road and it died basically straight away.
Posted 23rd Jan 2012 at 16:03
panks blaze
turned out to be corroded wiring.got it sorted by mark lightfoot.few days after the relay did pack up though.
black and gold
Posted 12th Feb 2012 at 16:04
Whereabouts in the vehicle was this corroded wiring found?
Posted 13th Feb 2012 at 18:49
ross1980
BUMP
I would also like to hear where this wire is as i am having problems with mine & it seems to be the same as the OP problem
I could have a sig but we are living in the stone age.
Scottish GTI-6 owner
Posted 23rd Jul 2012 at 18:18
Chris, from hitting a bump in the road and the car cutting straight away I would say that was more the inertia fuel cut off switch being activated rather than a failed relay. Wink
Posted 24th Jul 2012 at 11:07
Just to update this, mine was also a wiring issue to the fuel cut off (intertia) switch.
Posted 24th Jul 2012 at 15:07
Thanks for the update - was it corroded wiring or just broken wires? Unsure
Posted 24th Jul 2012 at 15:45
