Author Subject: 205 gti starting issue
scoty18
Hi, my pall has a 205 gti and he is having some issues trying to get it to start. He has tried the 205 forum and other places but thought Id give him a hand and ask you lot.. (I know this is the 306 gti forum, sorry if this offends anyone)
When you turn the key to the 1st position (as in one click) all the ignition lights come on and the fuel pump starts to whir. When you turn to the 2nd position the starter kicks in continuously (the car does not fire up tho there is no spark at the plugs). Then when you turn to the 3rd position (the one that springs back when you release the key and usually turns the starter) everything goes dead until you let the key springs back to position 2.
He has had the engine out and gave everything a bit of a tidy up, the car ran fine before. Since the fault occurred he has replaced the ignition switch and changed the engine wiring loom.
Any thoughts or suggestions would be appreciated..
I'm going out to his this week and would love to be able to fix the fault and get some beer tokens
Razz
Thanks Scott
  • TEAM DIABLO!!
  • Posted 16th Jan 2012 at 17:02
    b11 bob Banned!
    Razz
    Thanks Scott
    Possible bad earth conection or the amplifier unit ie the ignition module has gone or faulty spark plugs if you do go to start it make sure you take a fully working ignition module and coil with you and double earth the module otherwise you will blow that to
    205 GTI6 235 bhp at 7400 rpm
    Posted 16th Jan 2012 at 17:15
    its unlikely to be a bad earth or ignition amp, sounds like he has has f*cked up the wiring, tell him to put it back how it was LOL
    Posted 16th Jan 2012 at 17:25
    scoty18
    Yea the problem is he has put it back how it was or at least how he thought it was.
    I'm assuming the ignition wires go into a plug that just plugs into the ignition switch so they cant be fitted the wrong way around?
  • TEAM DIABLO!!
  • Posted 16th Jan 2012 at 17:41
    as long as he hasnt cut them off.
    Posted 16th Jan 2012 at 18:05
    heidi6
    I had this when I put a 16v in mine. Turned out I'd connected one of the wires wrong in the brown connector by the steering coloumn, where the loom enters through the bulkhead. Check the smaller of the two. Iirc there's a thick blue wire and that was connected wrong. May help?
    I live work (to pay) for the 306
    Phase 3 Astor. Built on Wednesday, 12th April 2000 in France.
    Years of 'Creative Maintenance' mean this car is now much lighter and slightly more 'race' specced... Tee hee
    Posted 16th Jan 2012 at 19:04
    fatlapit
    dead ecu???
    i had all my light on the dash and it turning on my 8v turbo and it wouldnt start, found out the ecu was dead
    Posted 17th Jan 2012 at 23:56
    allanallen
    If he's connected everything back up to how it was originally I'd start by looking at things he's changed. You say ignition switch? Do you mean the barrel/where you put the key? If so that'd be a logical place to start, try fitting the original part back on.
    It does sound like the starter wire and a switched live are the wrong way round or similar though.
    Al
    Facebook
    Posted 18th Jan 2012 at 07:37
    The barrels can become fooked over time, but sounds like a wiring problem.
    Posted 18th Jan 2012 at 12:40
    spiky
    I'd say big fat earth cable from chassis to gearbox is either knackered or dirty contacts on that cable
    I had this on my own 205
    MY YouTube Videos'
    268+BHP and 860kg = FUN
    Posted 18th Jan 2012 at 19:08
    spiky
    The starter going on the second notch could possible be down to the loom mixing pre and post 91 looms
    They swapped the ignition live an start over
    Get a pic of the 9 an 6 pin plugs under the steering coloumn
    Probably just needs to swap two cables over
    MY YouTube Videos'
    Posted 18th Jan 2012 at 19:10
    maddriver9
    Did you say your mate has changed the loom. When my mate changed his engine this happen.
    Turned out the for some reason that on later cars the loom was slightly different. His was a f plate and the new loom was k. We just swaped the to ignition wires over on the barrel and it was fine. This is only what I have seen and been told so please don't attack me if I'm wrong.
    178bhp 205gti6
    ¼ mile in 14.2
    Posted 19th Jan 2012 at 12:20
