Author Subject: Gti6 rack on HDI?
dan86
As above. I have a choice; fit new track rods to the HDI rack in situ or fit the track rods to a Gti6 rack that I have and fit that to the HDI. The HDI steering feels very light and slower geared than my Gti6 and would prefer the better response. Is this something that would be a straight swap? Are there different drive splines between the column and rack input?
The Gti6 rack is from a '97 P2 and the HDI is an '01 P3. Also I'm not sure if the HDI has variable power steering or not. According to servicebox the HDI has a 4000 CL and the Gti6 has a 4000 V7.
Thanks in advance.
Posted 15th Jan 2012 at 11:14
atterz
Should be a straight swap mate!
owain wrote:
Posted 15th Jan 2012 at 19:37
dan86
It was a straight swap. Thanks.
It's all fitted now and tracked up. It drives much better now; more responsive, quicker turn in and slightly heavier with more feel. It complements the Gti suspension very well. Chuffed.
Posted 15th Jan 2012 at 21:04
atterz
Glad it went well mate.
Posted 16th Jan 2012 at 12:57
hope you swapped the pas ram or you wont be able to turn right!
Posted 16th Jan 2012 at 13:02
chrisd306
Will cause wheel to rub on the box as welshpug said and make it an mot fail unless you use a shim
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 16th Jan 2012 at 13:10
dan86
Yeah used the HDI ram. Smile
Posted 16th Jan 2012 at 16:49
chrisd306
Wheel will be rubbing the box and will eventually rub through
& Audi Q5 S Line
Posted 16th Jan 2012 at 19:57
dan86
It's a Gti6 rack fitted to a P3 306 HDI 5 speed. Wink
Posted 16th Jan 2012 at 21:19
atterz
Big grin i wanted to say somthing but was starting to get confused myself! So its the rack that makes it feel different/heavier on the 6. Thought it may be the pump with a pressure limiter or somthing of the sort.
Posted 17th Jan 2012 at 18:22
darkgti6
Cant you also fit a zsara vts rack to the gti6? It requires less turns lock to lock or something?
Team Peugeot Sport 308 Gti�
Posted 17th Jan 2012 at 18:35
atterz
Yes mate, phase 2 Xsaras have a closer rack, common mod!
Posted 17th Jan 2012 at 18:55
chrisd306
Well dan I will shut my face lol
& Audi Q5 S Line
Posted 17th Jan 2012 at 21:00
dan86
I didn't make it that clear in the first post and also I shouldn't have been posting about a vehicle that uses the "devil's fuel" anyway so you're off the hook Smile
Posted 17th Jan 2012 at 21:14
dan86
I'm not sure TBH. It was an experiment. The HDI rack was very light to steer vs my Gti6 so thought I'd give it a go. It definately feels higher geared/quicker to turn in so I assume it is geared differently. There is mention of a variable steering rack on servicebox; maybe the HDI uses one that makes it light at low speed for easy parking etc?
Posted 17th Jan 2012 at 21:23
chrisd306
I have a d turbo aswell so your ok mate
& Audi Q5 S Line
Posted 17th Jan 2012 at 23:06
