Author Subject: newb after some track prep advice
COSSIEDRIFT
Hi lads i have had a traul through the search but can't find what Im after.
I have just bought a s reg 6 that i want to use as a budget track car. what mods could you recommend?
Many thanks Danny.
Posted 9th Jan 2012 at 20:41
Suspension, light weight alloys, tyres, brake upgrade
Standard engine will be good for now
Posted 9th Jan 2012 at 20:48
No cheap sh1t suspension either Thumbs up
matty_rallye
Decent tyres (R888's, A048's etc), decent suspension (chage arb, solid rear beam mounts, bilsteins or something similar) decent LSD or Quaife ATB diff, decent front pads (Mintex 1155's or similar) with dot 5.1 fluid + braided lines.
Would be the things i'd look at if starting again.
2.1 16v 306 Rallye.
Posted 9th Jan 2012 at 21:00
rallyeash
thermostatic oil cooler
decent suspension setup
Mintex 1155 pads, Brembo discs, braided lines, dot 5.1 fluid
decent tyres, lightweight wheels if funds allow.
solid beam mounts, larger rear arb
decent lsd
then go have some fun Smile
309 3dr K20 Type R
Posted 9th Jan 2012 at 21:02
timing belt and a service, JOB DONE.
Posted 9th Jan 2012 at 21:13
peetypug
Paid membership is one of the first things I would buy Thumbs up Wink
Cherry rallye - DOB Thursday 29/04/1999
Team Rallye - the leaner, meaner, better looking sister of the GTI6 Big grin
roland rat wrote:
You sir either live for the 6 or have a mental retardation to still be repairing this!
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fecking temperamental.
Posted 9th Jan 2012 at 21:40
COSSIEDRIFT
Have bought some 888's. what suspension I've booked brands hatch for next month so i need to get it sorted.
Posted 9th Jan 2012 at 22:51
standard, just learn to drive it first before you mod it Smile
Posted 9th Jan 2012 at 22:54
24seven
^^ What he said. When the time comes don't go lowering it stupid amounts either, you'll only ruin the handling. Schoolboy error.
Posted 9th Jan 2012 at 23:27
mattgti6phase2
Ride height doesn't matter a f*ck. It all depends on the components!
Welcome btw.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 9th Jan 2012 at 23:56
miles
Good wishbone bush's too
www.pugracing.com
Posted 10th Jan 2012 at 02:41
aphyx
decent lsd
I thought the oil cooler plate was thermostat controlled as standard but just lacked a decent cooler, I was under the impression you could plumb a cooler onto the standard oil cooler but I was never 100% Dunno
Onward to the Edge!
Posted 10th Jan 2012 at 18:31
decent lsd
I think Ash meant to get a Mocal thermostatic take off plate plumbed up to an oil cooler rad. There are non-thermostatic ones by mocal too which are cheaper, but they make it take much longer to get the oil up to temp and thats a bad thing.
I've not read anywhere about people plumbing into the standard heat exchanger, the thermostatic sandwich plate does sit between that and the oil filter though. Smile
Posted 16th Jan 2012 at 17:52
af1-gti
Have a look through Owains thread
Rich E wrote:
With the 306 Rallye the goal wasn't to make a purer or more focussed car. It was to make a cheaper car, and then cynically use Peugeot's motorsport heritage to make it appeal to enthusiasts.
Posted 16th Jan 2012 at 18:03
