Author Subject: petrol leak
parrotno1
just been washing my car and noticed smell of petrol, i bent down under the drivers side rear wheel and there is a slight drip up under the hoses in the arch. any one had this before, common thing? common parts that fail?
thanks in advance
Posted 9th Jan 2012 at 14:28
funkymonk
Clicky Thumbs up
There are only 10 kinds of people in this world, those that understand binary and those that don't...
Posted 9th Jan 2012 at 14:36
parrotno1
many thanks funkymonk, search engine never seems to throw up anything? the problems have commenced! :-)
Posted 9th Jan 2012 at 14:44
It's probably the shittest of shit jobs too. I nearly torched the car when I did mine... I had a new one though and they are sooooooooooo stiff. Get thick rubber gloves and but the pipe in water from the kettle first so it softens up
Posted 9th Jan 2012 at 17:22
It is a bas**rd to get the pipe on, how such a easy job could turn out to be a bit of a bas**rd I don't know, the pipes not dear from pug and don't buy the new jubilee clips as they make you buy a bag of 20 which I did so if you need 2 jubilee clips then let me know and I can supply them for p+p
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 9th Jan 2012 at 17:25
I had the new type though. Looks different and is thick as f*ck. It's basically a brute strength job tbh. Unless you drop the tank
Posted 9th Jan 2012 at 17:29
Mine was the new one also, it takes strong fingers to get it on
Posted 9th Jan 2012 at 17:34
gota6again
I had this a while ago and it's fiddly but fairly easy, also as a cheeky and shameless plug I have a more or less new elbow you could have for a tenner posted Whistle
Posted 9th Jan 2012 at 17:38
allesclar
what i did, was to leave the silicone joiner in boiling water for 10 mins, sprayed a little of WD40 around where it needed to go and it went on a few swear words later Smile
Team allesclar ®
Posted 9th Jan 2012 at 17:46
tvrfan007
It's not the easiest job but it's not exactly taxing. Elbow from the filler to the tank is likely culprit however I did have a leak from the feed line on my hdi where it came off the tank top on the run from the tank pump to the bay, that was a bigger fix.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 9th Jan 2012 at 17:51
I just used some water based lube from the sex shop it's really slippy so I rubbed it all over the pipe and the neck where it fitted with and that worked a treat, I also put it in hot water but by time id fannies about trying to get it on it had cooled, it's not hard it's just diddly and does take some force with the fingers.
Posted 9th Jan 2012 at 19:15
Water based lube from the sex shop.....lol. Andy, you crack me up!
Posted 16th Jan 2012 at 08:26
