Author Subject: GTi6 turbo build
JWP EFi
Turbo Legend!
Ok, i have been dabbling with the idea of building a 16v turbo engine for the past couple of years, this has stuttered
and stalled several times due not being able to decide on the best possible way to go, so once again im going to try
to see it through.
Parts i have stock piled:
Low miles XU10J4RS from a 2002 xsara vts
90k xantia 8v turbo lump
genuine 405 T16 exhaust manifold
Garrett T3 from sierra cossie
cossie Level 8 ecu, all its various sensors, injectors etc etc
Cossie throttle body
Quaiffe diff
My biggest problem is what bottom end do i build, various options,
1)use the 8v turbo bottom half, but mine has the later dished pistons so i would have to machine approx 0.8 - 1mm off
the face to allow valves to clear, however i'm not sure the deep dish will work in conjunction with 6 head. other
benefits of using this one is that it already has turbo oil feed and drain points.
2) use my complete gti6 bottom end and machine approx 1.8 mm off the pistons and use the thickest gasket i
can get.
3) again, use gti6 but with a Decompression plate from the likes of Ferriday engineering, but always worry about
the seal between plate and block.
i have also looked into sourcing and modifying C20LET pistons which share the same bore size and are factory forged
ideally i want to use the early 8v turbo flat top 8:1 pistons but cant find them anywhere, believe me, i have searched
high and low
I am very tempted to do the decomp plate thing but at the same time i think the 8v turbo bottom end would be the
way
to go, given that its a factory turbo uprated setup
Anyway next problem, i have done various dummy builds and when i fitted my T3 to the manifold, the exhaust
housing is too close to the head - no where near enough room for a downpipe. What i need is an Escort RST
exhaust housing (same A/R's as cossie t3) which is a far neater design and would give me a 5 bolt downpipe
pattern, i believe this is what Ecosse did/do to get around the problem
Also looking at TD04/05 turbos for scoobs/evos, these are very plentiful and are ideally suited for what im doing
Management wise i'm looking to use a sierra cossie L8 ecu with a wasted spark conversion as the 6 obviously
doesnt have a distributor! Basically i need to solder a Wasted spark driver to the cossie ecu then run 2 ignition
amplifiers along with a 8v turbo coil pack and leads, coil will be fixed to end of head via 5mm ally plate
I personally know of someone who has done this and it works very very well, plus when Ecosse done their T16 sedan
they used the slightly newer cossie 'P8' ecu with Pectel board.
Description of whats needed for cossie ecu conversion:
Ecu £50 - £350
wiring loom, ive bought an ecu 36 pin plug and made a new loom rather than cut / alter an ageing ford one! £180
PF09 TPS £40
Air & Water temp sensors £30
Crank position sensor £30
Phase sensor £20
Amal valve (boost control) £25
set of IW-044 injectors (good for 270 bhp) £80
Sierra 4x4 throttle body with idle control valve £90
Wasted spark driver £140
Loom for above £65
twin ignition amps £60
PSA coil pack and 8v leads
Have to figure out a way to fit a cossie trigger wheel to the crank pulley, cossie's used an unusual setup, 4 teeth
spaced 90 degrees apart
finally modifying gti6 vacuum pump for the phase sensor, im using the sierra's distributor trigger wheel mounted
onto the vacuum pump shaft, very very difficult but dooable
At times i wish i'd not bothered with the cossie ecu idea as there is so much to buy and so many things have to be adapted. I did briefly consider using Calibra C20 LET manaement as this alraedy has the 60-2 crank position sensing
but nobody does a wasted spark conversion for it and i'm not clever enough to think of a way round it!!
Obviously stand alone, Megasquirt, omex etc, is the way to go but iv'e already gathered £100's worth of cossie bits
and its proven to work so, right now, this seems the best way to go, for now...
Power wise, i'd be over the moon with around 250 bhp with similar helpings of torque, this will never be a track
car so for road use i think this is a decent 'goal' to aim for, obviously any more would be a bonus!
There are lots more problems to overcome such as the termostat housing, the pipes come out in the wrong place so
will come into contact with a rather hot manifold, so only way (that i can see) round it is to blank the existing fittings
off, then drill the underside of the housing and fit 2 new fittings. Its easy to see why turbo conversions cost what they
do, so much redesigning/positioning etc etc pretty much everything needs to be made from scratch.
So there you go guys, over the next few months all these bits and pieces should hopefully come together to create
something along the lines of a T16, i will put pics up as soon as i can find a way to resize images, my computing
skills are some what basic!!
Posted 8th Jan 2012 at 12:43
Why not use the GTi6 standard ecu with a separate boost map controller? You can map the standard ecu to cope with different injectors etc. Speak to Wayne at Chipwizards or possibly Rich W at Lynx about what the standard ecu is capable of.
My T5 V70 runs a TD04-16T which is good for 300 odd BHp with very little lag. They are very, very cheap and very reliable. By the way i'm not sure the 8v turbo bottom end is all that great. The pistons aren't up to much iirc. Do any Saab engines run a similar size piston?
Posted 9th Jan 2012 at 15:24
JWP EFi
Turbo Legend!
ive looked at just about every piston option, the saab has a much bigger bore diameter, cant remember exact size
off top of my head.
the gti6 ecu: i'm really not convinced that it would work, as far as im aware they cant realise positive inlet pressure
yes, i know it works for superchargers but i think asking it to manage a turbo is pushing it.
i appreciate all comments/advice etc
btw, the TD04 16T is one of my potential choices
Posted 9th Jan 2012 at 21:50
there's no difference, its still boost, they are very capable ecu's.
Posted 9th Jan 2012 at 22:08
fatlapit
Speak to sos motorsport they are up in jock land they will be able to help you out.
Posted 9th Jan 2012 at 23:49
mabgti
NV motors
The standard 1ap has no ability to read positive boost, so its rendered no good. A piggy back ecu and another injector is the easiest.
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 10th Jan 2012 at 01:44
how the feck does it work on the superchargers then?? Unsure
Posted 10th Jan 2012 at 10:31
ruan
Reads the MAP before the supercharger (hence the silly long inlet tract - throttle>charger>intercooler>manifold) then since a s/c is linear and is always constant vs RPM, you know how much air is going in for a given RPM and TPS... Then does the fine trim off the Lambda I suppose?
Posted 10th Jan 2012 at 10:53
but the ecu doesnt use lambda on WOT?
why would you use a smaller cosworth throttle body BTW?
sounds like you need to use an 8v turbo ecu with a modified map sensor.
Posted 10th Jan 2012 at 10:59
rich_w
On the supercharger conversion, the throttle body is placed on the inlet of the compressor, with the pressure sensor placed between the throttle body and compressor inlet.
In this situation, the pressure sensor is used to measures from 0 (part throttle or vacuum condition) up to atmospheric pressure (which occurs at wide open throttle).
The pressure sensor is the main parameter for air metering. The throttle position is also used, but this is generally for compensations for acceleration and de-acceleration transients.
Lambda compensation is only used at part load.
Contact Details:
07732 822546
Posted 10th Jan 2012 at 11:08
JWP EFi
Turbo Legend!
if i want to go cossie management then i have to use its throttle body, because it has an integral idle valve and i cant
think of a way round it, plus it saves all the hassle of trying to custom fit the TPS to other bodies etc etc,
as for the bosch 3.2 ecu from the 8VT, according to Dastek they can remap/alter eprom so it will suit new engine,
i have played about with the map sensor on these before (my old phase 1 xsi 8VT) by adding resistors in, i could have
swore that i raised the fuel cut point a bit, but no dyno proof to back this up
Posted 10th Jan 2012 at 20:17
FatBastard
Funny, we use very similar parts in our projects! xantia turbo lump is RGX, no?
I used the RGX bottom since i could not trace a good GTI6 bottom and the XSI doesnt have oil squirters for the pistons.
How much power do you plan to output?
Posted 10th Jan 2012 at 21:38
JWP EFi
Turbo Legend!
xantia and 406-RGX, dished pistons XM and 605 RGY, flat top pistons, arguably same as T16
RGX/Y is a good block to use as it already has turbo oil feed and drains
my build is a budget one so no forged goodies here! i'm aiming for around 250 bhp, i think 250 in a 306 will make a
good road car. I just cant decide between machined RGX pistons/bottom end or just use the complete gti6 engine with
a decompression plate, look at what dp engineering get away with!
Posted 10th Jan 2012 at 21:59
birk
What about oil feeds on 6 block?
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 10th Jan 2012 at 22:27
ruan
There's a bolt in the back covering up a feed hole, in the same place as the diesels. Just get a Diesel oil feed line chopped with a compression fitting as the fitting on the block end is wierd.
Posted 10th Jan 2012 at 22:37
birk
Ah cool, cheers ruan, I will have to have a look when I take my engine out for the build.
07889376885
Dan
Posted 10th Jan 2012 at 23:15
chrisd306
A phone call to Dave at SOS motorsport he is soundsofsilence on here, or look up SOS motorsport on Facebook, they have built loads of 16v turbo lumps dir 205's and 306's and have went down diffrent routes but well worth a call or a pm
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 11th Jan 2012 at 09:03
fatlapit
thats what i said lol
Posted 11th Jan 2012 at 18:10
nadium
jsa666
this is what iam gooing to do just witha decomp-plate and lynx headgasket.
find danish 6 in projects
kenneth
Posted 11th Jan 2012 at 19:26
JWP EFi
Turbo Legend!
what thickness is the decomp plate and the gasket?
Posted 11th Jan 2012 at 21:46
T5D5 - TD04-19T at a decent price that I want but cant afford grrrr... Smile
Posted 17th Jan 2012 at 09:38
