displaying posts 51 to 75 of 79
Pages (4): first .. 2 [3] 4
Author Subject: Under Pressure !!!
ravemercer
Post #51
Just to rub it in did the compression test on my mate rallye to compare he got a 200 across the 4 lucky bas**rd lol
Posted 15th Jan 2012 at 16:20
darkgti6
Post #52
In your first post you wrote -
ravemercer wrote:
Been having a few problems with the cooling system and to cut a long story short.
Fan relays stopped working the car ran hot around 110c (No Stop Light)
Then in post 39 you wrote
ravemercer wrote:
Never had it gone above 100c at any time, well going by the gauge.
So which is it? Either the water temperature has gone over 100 degrees or it hasntCrazy
Team Peugeot Sport 308 Gti�
Posted 15th Jan 2012 at 18:02
ravemercer
Post #53
Taken in context with what Stan posted about driving about losing 3-5 liters coolant a day, during that time which was awhile after the matrix was fixed the car has never over heated or gone over 100c.
cheers
Posted 15th Jan 2012 at 18:19
Post #54
got a white wallye here for a HG in the next few days, goes well enough, but pressurises, never gone over 85 degrees.
just do it before its too late Thumbs up
Posted 15th Jan 2012 at 22:57
Post #55
This is the advice to take...Yes
Posted 16th Jan 2012 at 06:38
aaron6
Post #56
This may sound retarded but...
What is the outcome of a failed hg? Stan, was my blaze failing or failed when you had it to repair?
Posted 16th Jan 2012 at 13:15
Post #57
best case, minimal skim, set of bolts+gasket and away you go.
worst case, mayo in the sump and spun engine bearings and worn out bores, grooves in the head and warped heads, aka scrap.
Posted 16th Jan 2012 at 13:24
Post #58
Yours had the same symptoms as this one mate when I took it in. When I stripped it down you could see the failed part of the gasket. It isn't always obvious, but when you know what you're looking for you can spot it.
Posted 16th Jan 2012 at 13:32
Post #59
Mine was certainly going for some time before it finally properly blew. When it did though it went between two cylinders and grooved the head.
Posted 16th Jan 2012 at 14:32
ravemercer
Post #60
I'm on it going down to a pug specialist tomorrow after work, there going to have a quick look but straight away said sounds like HG,
like you all said a long time ago Whistle
Just trying to work out how I'm going to earn the money to fix it without having the car to get to work to earn it Dunno
Possibly going to get policy switched over to a mate's rallye and give it some cruise on the way to work.
What part would best be gen pug and any recommendations on other parts?
I am using the search but quick answer would be great.
Posted 16th Jan 2012 at 19:50
jbradders
Post #61
Guns No No
Posted 16th Jan 2012 at 19:54
Post #62
Your best off buying a genuine head gasket as it is very good quality and MLS.
As for us all saying it was HG a long time ago....Whistle
Stan.
Posted 16th Jan 2012 at 19:59
ravemercer
Post #63
I know I know I just didn't want to believe LOL
Just checked service box HG 0209z2 £42.46
Posted 16th Jan 2012 at 20:15
ravemercer
Post #64
jbradders wrote:
Guns No No
It could do with a decent run, might blow the dust off the roof Big grin
Posted 16th Jan 2012 at 20:19
Post #65
That's the one mate, not too bad a price to be honest. The rest of the items you can get from Pug or a factors. I generally use Gates belts and INA tensioners (which are standard Pug anyway). They are much cheaper from a factors, even though the parts inside the boxes are identical.
Good luck with it. Thumbs up
Posted 16th Jan 2012 at 20:38
ravemercer
Post #66
Cheers, going for a mix of parts maybe a shiny crank pulley if i can to match the flywheel I'll see if Lukes still doing parts through here.
Any ideas what would be a fair labour price for all parts fitted supplied by myself ?
Posted 16th Jan 2012 at 21:16
Post #67
The thing about buying the parts yourself and then getting someone else to fit, is there is no firm ground for blame to be aportioned if the worst happens.
The reason for this is the parts supplier will blame the fitter, and the fitter will blame the parts, leaving you with not much hope. The solution to this is either buy the parts and do the job yourself, or if thats not possible, give the job to someone else and get them to source the parts. Wink
Stan.
Posted 17th Jan 2012 at 06:43
ravemercer
Post #68
I see what you mean. I just dont like the thought of having shite parts being fitted to the 6 only want to do this once and the 6 should then be sorted for years to come. when i see the guy tonight I'll enquire about them getting the HG and cam kit through pug, showing proof. Was even Thinking rich's HG it's double the price of pug but should last longer especially as this would be the second skim on the head.
Posted 17th Jan 2012 at 10:11
ravemercer
Post #69
Also checked for pressure this morning and there was nout much less than opening a bottle of coke Dunno
Posted 17th Jan 2012 at 10:13
Post #70
probably leaked out overnight, or the cylinder is full of water LOL
Posted 17th Jan 2012 at 10:58
Post #71
If they are a Pug Specialist they 'should' be using Pug parts anyway.
Posted 17th Jan 2012 at 11:41
ravemercer
Post #72
lol nope its all good well sort of the pressures back. Smile
Posted 17th Jan 2012 at 17:26
ravemercer
Post #73
The guy said the only gen part he would use would be HG. Booked up with someone else anyway thought f*ck might as well put something shiney on there at the same time aswell.
Posted 17th Jan 2012 at 17:30
aaron6
Post #74
Who'd ya book it with mate?
Posted 17th Jan 2012 at 18:06
ravemercer
Post #75
Rich @Lynx . Booked in for next week.
Hope it all goes well next week, I've got to keep using it until then doesn't seem to be getting worse at the moment. I did try to get the spare van from work, would of been Ok, however some numpty rolled it friday.
Posted 17th Jan 2012 at 20:00
