Author Subject: revs behaving weird *SOLVED*
allesclar
Hey all,
Got in the car to find the revs idling around 2k revs. Any obvious issues, dodgy sensor?
I can drive the car ok, just when i clutch down to change gear it pops straight to 2k revs again.
Team allesclar ®
Posted 4th Jan 2012 at 23:48
broken fuel pump relay, or broken ICV.
Posted 4th Jan 2012 at 23:53
allesclar
ok thanks mate,
i did try search but found nothing with this particular issue.
might try giving some of the cables a clean. :/
If it is either of those two, whats the rough cost for either off the top of your head?
Team allesclar ®
Posted 4th Jan 2012 at 23:58
honestly3k
Can get a good used ICV for £25 i should think and fit it yourself, they are a piece of p*ss
Fuel relay wouldnt be much either imo
Posted 5th Jan 2012 at 00:21
woody.
Pug want £140 for a new ICV. I went here and its still running fine 10k down the road:
online automotive
Posted 5th Jan 2012 at 02:39
rich_w
It's probably eithe the ICV or an air-leak somewhere.
Check all of your boost pipework is properly clamped up etc Smile
Contact Details:
07732 822546
Posted 5th Jan 2012 at 09:43
Icv is about £90 ish from Ecp
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 5th Jan 2012 at 11:38
Posted 5th Jan 2012 at 11:40
allesclar
thanks everyone, i will have a look at the weekend as its abit too dark atm.
Adam
Team allesclar ®
Posted 5th Jan 2012 at 18:03
I'm with Rich here, either the ICV (might as well try and clean it first before buying a new one) or an air-leak.
Posted 6th Jan 2012 at 07:32
When I had air leak with my low boost setup, the revs would hang after letting off the pedal for a moment then when it dropped it cut out.
yours isn't doing this so I'd look at the icv first.
Posted 6th Jan 2012 at 20:15
allesclar
well,
i thought it might be the hose between the charger and the intercooler.
nope, i took the ICV cable off the charger area, gave it a quick squirt of WD40, wiped it clean and on the socket itself, and hey presto.
Just needed a clean. Thanks for the help everyone anyway Smile
problem solved
Team allesclar ®
Posted 9th Jan 2012 at 21:08
Glad you got it sorted mate. Wink
Posted 9th Jan 2012 at 21:11
