Happy to be back in a 306 again!
| Author | Subject: Relays |
simbob
Regular Location: cinderford Registered: 18 Feb 2010 Posts: 337 Status: Offline |
Hi all I hope someone can help. I replaced my fogs and bulbs, they worked for an hour or so but now nothing, every time I turn the fogs on I get a click which means relay. Does anyone know for defo which relay it is and were it's located cheers sim________________________________________ Happy to be back in a 306 again! |
dan_s16
Seasoned Pro Location: Cheltenham Registered: 22 Jan 2005 Posts: 1,583 Status: Offline |
It's one of the green ones next to the fuse board (I just can't remember which one as it's been a long time since I had to look at mine), just put your finger on top of one of them and turn the fogs on and off, you'll soon find it.If the relay is ok (pull it out once you've found it and make sure the socket and pins are ok and swap one of the other green ones over just to check it's not the relay). Also check the fuses and earth points (I believe the fogs are grounded to the same points as the headlights, on the chassis rail behind each headlight). ________________________________________ When I've got time I forget what I wanted to do, and when I remember what I wanted to do, I have no time! |
simbob
Cheers dan________________________________________ Happy to be back in a 306 again! |
