Author Subject: Removing Instrument panel/speedo
monkeyman
Which torx sizes do I need to get at the instrument panel? I've removed the two small ones above the panel, there look to be two behind the steering column, and two more holding the steering column plastic in place, but my allen key set isnt long enough to undo these. I'll pick up a set of torx drivers but which do I need, I'm guessing a 10 and 15 with about 7-10cm reach, but are there any others lurking behind the dash?
Forum Search Clicky
Posted 3rd Jan 2012 at 12:53
simonjames
iirc its a 10
MY EBAY ITEMS
07943066306
Posted 3rd Jan 2012 at 12:58
m306
You need to remove the 2 under the steering column that allows you to take the top cover off then there's 2 at the bottom, easy to see, then pull that cover off. Then it's 2 at the bottom and 1 at the top to remove the instruments, oh and 2 plugs behind.
supercharged China gti6 - Thu 16th Sep 1999 - sold
2010 megane rs250
Posted 4th Jan 2012 at 10:00
