Author Subject: battery drain faq
tvrfan007
Is it just me or is this faq corrupt? I seem to recall it being comprehensive?
dead battery troubleshooting
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 2nd Jan 2012 at 15:47
It would seem it, one of mine is corrupt too but can't remember which one. Also noticed is the amount of missing threads started as I tried to search for something today and noticed I was down to three pages of threads started.
Posted 2nd Jan 2012 at 18:31
hampstead
It's the pound sign problem. Everything after one of them in a post disappears. In this case, the entire FAQ :-( Could really have done with that over Christmas too!
Matt
Posted 2nd Jan 2012 at 19:15
jimmy_boy
Bugger!
I'm guessing they're all lost after the transfer to the new forum then?
Sad
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Posted 2nd Jan 2012 at 21:09
jimmy_boy wrote:
Bugger!
Sad
Nope, just some anomalies.
Posted 2nd Jan 2012 at 21:39
tvrfan007
Wayback machine ftew!!
Anyone want to correct or add anything to this for an FAQ?
FAQ for drained battery problems.
For diagnosing these problems accurately you are going to need a multimeter. I paid about £10 for one on ebay.
1. DONT TOUCH ANYTHING!
Before anything else carefully check controls in the car to see if you have left a light or other equipment turned on. This could save you a lot of time diagnosing problems later if you don't just start fiddling with stuff.
2. Check charge in the battery.
Set multimeter to 20volts. Plug your black probe in COM and red into Volts.
Place black probe on negative terminal and red on positive.
Read multimeter - A battery should be knocking out about 12v. Even 1v less could mean a flat battery and the 6 engine needs every last drop to start it seems.
If the reading is less than 6v, skip it - The battery is dead.
If 7v or more then you can re-charge the battery using a charger (£38 from halfrauds).
3. Check for parasitic drain.
Remove the negative terminal from the battery.
Set your multimeter to 10 Amps.
Plug the black probe into COM and red into Amps.
Place the black probe onto the terminal on the lead to the car, and the red onto the negative post on the battery.
The MM should read a mili-amp figure.
Around 20-25ma or less should be fine - this will be clock, hifi battery, ecu etc. (Mine was around 16ma).
25ma and greater and you may have a drain somewhere.
4. Identify drain.
Using step 2 to check drain after each step, remove fuses from the fusebox one at a time - noting what they affect - until the MM reads 25ma or less. When it does - check the wiring carefully of the components that fuse supplies.
See Fusebox FAQ's for full list of fuses and their function.
5. Check earth points.
Check all these earth points round the car are securely fastened and clean.
one by the abs pump
one by the drivers side headlight
one on the gearbox
one in the drivers footwell
one under rear bench seat (i think)
one behind the cover in the boot (the side with the boot light)
6. Check battery terminals.
Make sure the posts and the terminals on the leads are clean so they make a good connection.
DO BELOW ONCE A CHARGED BATTERY IS IN PLACE.
7. Check lights.
When battery is charged, check all interior lights go out. Fold the rear seat down to check the one in the boot while it is shut.
8. Check alternator
Start the engine and turn on lights and fan and hold at 2k revs (easier if someone else does this than trying to use throttle and MM at the same time!).
Set MM as before when checking battery charge.
Test the voltage across the battery terminals with the engine at 2k and you should see a figure of around 14volts.
If it is still only 12v then your alternator is not charging the battery. Check the alternator belt is tight. You may require a new alternator. It may also be a faulty regulator.
(I found I didn't even need to rev the engine, it read 14+ volts when running regardless of engine speed. Your results may vary).""
I'm Si btw Tee hee
Yes if you have any inbuilt charging e.g. phone charger cradles set fuse for lighter to ignition only, see fuse faq.
Posted 2nd Jan 2012 at 21:42
tvrfan007
bump for admin to fix the FAQ Smile
I'm Si btw Tee hee
Posted 20th Apr 2012 at 19:21
This is now fixed. Cool
Posted 20th Apr 2012 at 19:34
jimmy_boy
Excellent! Clapping
I'm glad the old info was recoverable.
GTI-6 & Rallye
Posted 25th Apr 2012 at 19:43
Same as that Jim...Smile
I just hope we can recover and restore as many of the broken ones as possible as thats what makes the section so valuable.
Guys, if you find anymore that are seriously corrupt or broken, please let one of the Admin Team know and we can set about trying to fix it. Cheers
Posted 26th Apr 2012 at 22:39
