Author Subject: Is it an easy job to install an oil temp gauge?
eddiebeano
Hi there, could someone advise me what parts are needed to install an oil temperature gauge on a pillar pod? I'd be looking for a gauge like the following:
Clicky
If someone could tell me exactly what would be needed that would be great, thanks.
Ed
team: Stealth Ninja
Posted 1st Jan 2012 at 19:27
shouldn't your car have one already?
Posted 1st Jan 2012 at 19:34
eddiebeano
Yes it does, but it doesn't seem to move.. I guess it's the senders fault as it does the oil level check when I first start the car up. Once fixed is it accurate enough?
team: Stealth Ninja
Posted 1st Jan 2012 at 19:39
bennn
I'd have thought so, how accurate does it have to be?
Cherry Red 306 HDI
Posted 1st Jan 2012 at 19:40
eddiebeano
more accurate than my oil level check that's for sure..
To be honest, Id just like an easy to read gauge, partly for show, partly because I like the keep an eye on things. Can anyone answer my original question without worrying themselves too much about my motives?
team: Stealth Ninja
Posted 1st Jan 2012 at 19:42
just fix the original Thumbs up
Posted 1st Jan 2012 at 20:36
You will need a sender and a gauge and the wiring in between that's about it. I'd fix the original if I was you not a massive fan of gauges on the pillar
Posted 1st Jan 2012 at 21:05
Check the wiring plug is on the standard senderThumbs up
On the front of the sump a couple of inches up.
My standard one seems to work spot on,sits nicely under normal driving,give it some stick for abit and it rises as it should,then drops down when you slow down again.Roll eyes
The trouble with those ones in your link is those bodgy sump plug adapters for the senderYes
If you could find a aftermarket sender that screws into sump where standard sender goes it would be a better set-up and readingSmile
Posted 1st Jan 2012 at 21:12
eddiebeano
Thanks, some helpful advice there. does everyone else's gauge look like this? I'm not sure I even have a temperature gauge now!
I think it looks like the one on the left, which is just an oil level gauge..
team: Stealth Ninja
Posted 3rd Jan 2012 at 15:32
bennn
Is it a GTI 6 you have?
If so it doesnt have the right dials in it. The gauge in your picture is just a level not a temp gauge (which is fitted to the lesser models) also note the redline on your dials is at 6250 as opposed to 7250 in a 6.
It will measure your oil level when you switch on the ignition then go off after ten seconds or so.
If the clocks have been swapped odds are your mileage is incorrect.
Cherry Red 306 HDI
Posted 3rd Jan 2012 at 15:45
jim01uk
Even people who have paid to be members can't be f*cked to post in the technical section LOL
Posted 3rd Jan 2012 at 15:47
eddiebeano
Yep its a 6. It was an import originally bought in Cyprus by an army officer then exported to the uk. I've noticed it doesn't have an alarm switch on the steering cowl either. I'm guessing it never had one, hence it has a toad alarm. It does redline at 7250 though! might they have a different spec for non uk cars~?
team: Stealth Ninja
Posted 3rd Jan 2012 at 16:04
bennn
My guess would be its had the clocks swapped so it reads in MPH instead of KPH when it came over here and they’ve accidentally swapped the clocks over for those out of a lesser model.
Could have been swapped over when new so the mileage might be correct.
I also would have thought that if you stick a set of GTI 6 clocks in it you’re oil temp gauge will work
I think it’s possible to swap the mileage computer over when changing dials over if you wanted to keep the mileages consistent.
Cherry Red 306 HDI
Posted 3rd Jan 2012 at 16:12
eddiebeano
Ah yes, I never thought about the original clocks being in kph. Thanks for the help.
Ed
team: Stealth Ninja
Posted 3rd Jan 2012 at 16:18
bennn
No probs. Im not even sure that they drive in KPH in Cyprus but thats one theory.
It’s worth getting hold of a set of 6 clocks and swapping them over as the temp gauge should work fine then.
It’s a lot less hassle and will look better than an aftermarket pillar type gauge.
Cherry Red 306 HDI
Posted 3rd Jan 2012 at 16:23
Rich E Forum Admin
Yes, KPH in Cyprus. It wouldn't have passed the DVLA import inspection without an MPH speedometer.
Posted 3rd Jan 2012 at 16:24
