Author Subject: Battery died and car was deadlocked
v6saloon
Hi guys, my mrs has a 306 xsi and it doesn't get used very much so the battery tends to run flat now and again.
It had beed stood for a while and had beed locked and deadlocked, i went to open it and the battery was totally flat so tried to open with the key in the door and it unlocked but the deadlocks are still locked Crazy
So i was just wandering if anyone had experianced this before and has any advice on the best thing to do, is it possible to open the bonnet from underneath to get to the battery? thanks in advance Smile
205 mi16
405 Mi16x4 restoration project
406 v6 saloon track car project/daily driver
508 Hdi
Posted 30th Dec 2011 at 22:14
peetypug
Are you sure the door just isn't stuck/rusty hinges?
Have you tried the passenger door and boot locks?
Cherry rallye - DOB Thursday 29/04/1999
Team Rallye - the leaner, meaner, better looking sister of the GTI6 Big grin
roland rat wrote:
You sir either live for the 6 or have a mental retardation to still be repairing this!
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fecking temperamental.
Posted 30th Dec 2011 at 23:23
v6saloon
Yes all the doors are the same, and the boot doesn't have a key hole; the deadlocks are the only things i can think of
205 mi16
508 Hdi
Posted 30th Dec 2011 at 23:57
mattgti6phase2
Yes it will still be dead locked. Bit of a problem you have there.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 31st Dec 2011 at 12:06
aaron6
Pm stilly. He did this and im not sure how he got round it but he did.
Posted 31st Dec 2011 at 12:49
stilly
get under the front of your car and with a long screwdriver, you will need to open the bonnet...once bonnet is open you can then gain access to you battery and charge away...hope this helps
deaf in 1 eye blind in 1 ear Crazy......
307 136bhp daily drive.....
306 rallye stripped out and charged.....
lee_gti6 also known as "the tit".....
stan_306gti6 also known as "stan the dick".......
Posted 31st Dec 2011 at 12:55
atterz
Should still be able to open the drivers door if you put the key in manually with a bit of force to the open position. I deadlock my DT and disconnect the battery whilst its off the road.
owain wrote:
Posted 31st Dec 2011 at 16:52
peetypug
That's what I do to my meridian, it's never failed to open with the key manually
Posted 31st Dec 2011 at 19:38
v6saloon
Thanks peetypug, i will give that a try tomorro
205 mi16
508 Hdi
Posted 1st Jan 2012 at 02:32
v6saloon
205 mi16
508 Hdi
