| Author | Subject: can u get the black bit in metal??? |
fatlapit
http://www.google.co.uk/imgres?q=peugeot+306+gti+thermostat&um=1&hl=en&sa=N&biw=1366&bih=650&tbm=isch&tbnid=8r9U-zNgQDfUEM:&imgrefurl=http://www.306gti6.com/forum/showthread.php%3Fid%3D137086&docid=B4bQqt172eLStM&imgurl=http://i151.photobucket.com/albums/s160/j1m306/Parts/DSC00926.jpg&w=1024&h=768&ei=Np74TubdCcaf8gOZjoW5AQ&zoom=1________________________________________ |
Nope but I think you can change it for the 205 set up which is metal I think ? |
fatlapit
just i think my turbo will melt it________________________________________ |
I'm sure the 205 has a metal version but not sure ? |
what are you talking about?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
clen666
You can fit a metal outlet off the 205, but needs an adaptor plate that bbm can supply. The fitting is just a push-on rather than the circlip type 306 job________________________________________ Team 'unintentional rat look' |
what about the rubber hose connected to it?.....________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
clen666
good point________________________________________ Team 'unintentional rat look' |
fatlapit
I need a metal elbow not a plastic one as it may melt welshpug________________________________________ |
fatlapit
Hose aint a problem________________________________________ |
orly?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
fatlapit
what does orly mean???welshpug! wrote: orly? ________________________________________ |
fatlapit
cheers i just use a different hose________________________________________ |
I think it would be fine as long you as you use a heat shield ? After all it's hardly made of chocolate |
fatlapit
Fair shout________________________________________ |
