Author Subject: trouble starting after been started
slywhite
hi all, im having a bit of trouble with my car after first starting and running, if i stop the car and leave for a few minutes and start it again it takes a while to fire up, the fuel pump is kicking in and got fuel to the fuel rail, it fires up then dies repeat this process a few times and does the same so give it a few revs and its fine. but then i go to set off and put some throttle on and the revs die right down, keep tapping throttle and it does it for a while. once i have got driving it drives as it should. i have changed the stepper motor for another i have and its still doing it, this is driving me mad now. what should be a simple drive is turning out to be a pain in the ass. does anyone have any ideas or had the same issue? thanks in advance, simon.
Posted 19th Dec 2011 at 19:01
darzmat
idle control valve?? maybe strip and clean it.
Posted 19th Dec 2011 at 20:42
slywhite
icv/stepper motor cleaned and changed for different one does it with both. one i had on old engine and one i got with new engine. is it possible both are dead? anyone know how much they are new and where best place tget one from?
Posted 19th Dec 2011 at 20:52
judge dead
check there are no air leaks as i had something similar once and seen few other posts on this check airbox hoses
Posted 19th Dec 2011 at 20:59
slywhite
does this either with air filter on or off, all silicone hoses with jubilee clips are tight on induction kit.
Posted 19th Dec 2011 at 22:19
jimbamboon
mine used to do something similar to this after it had been started and warmed. Changed most bits, never solved it though, hope you have more luck
clicky code for my benefit
Posted 19th Dec 2011 at 23:32
swiftyboi006
Has the car ever overheated? Could be shoddy plugs after they have been heated
Black p3 Love
Posted 20th Dec 2011 at 17:42
slywhite
not on the new engine i dont think, and they were a new set off plugs i put in when i changed the engine over. will have a tinker with plugs and sensors, will post if i find anything. thanks for the help so far.
Posted 20th Dec 2011 at 18:34
swiftyboi006
Pretty sure it will be a sensor then, give them all a clean
Black p3 Love
Posted 20th Dec 2011 at 19:31
When he says air leak he means after the throttle body, resonator box cracked or inlet manifold or throttle body gasket leaking eg
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 20th Dec 2011 at 20:32
judge dead
guy had this problem after putting the ptfe i think its called manifold gasket on and it was letting air in
Posted 20th Dec 2011 at 20:46
Mine was like this when. Had a split boost pipe,it was fine for first 5 mins, somebody said that's because idle control valve is fully open when cold
Posted 21st Dec 2011 at 16:11
slywhite
this is a new problem after sorting out the ptfe gasket. i have just about had enough of my car now seriously thinking of getting rid. went to it the other morning and battery was dead no probs i'll jump it off, so i do and get on my way to realise that the interior fan isnt working, ok i will put my window down for now, get to my destination and come to start again and it has its shitty on again. came home parked up swithched off, done. went to it again this morning and guess what, yep dead again, alternator is charging fine battery is holding charge off car but not on, put multimeter on battery on car and it doesnt drop over a couple of seconds, it takes hours to drop ie over night. dont even know where to begin. so as you can see what a great xmas this is.
Posted 23rd Dec 2011 at 18:46
swiftyboi006
Battery is being drained from somewhere that uses a small amount of power. Check all your fuses under the dash i bet theres a blown 1.
Black p3 Love
Posted 25th Dec 2011 at 16:05
slywhite
took a while but i now think i might have this sorted, the battery dying was a fooked halfords battery so changed to a new one and no problems. as for the starting issue after running i have had it on a diagnostics machine and i have a knackered temp sensor that is reading -40 lol, and a dead engine speed sensor, also the oxygen sensor is coming up because of the temp sensor which is causing most of the problems. just letting you know so if anyone else has these issues you know what to check.
anyone know how much a temp sensor of pug are? or where else to get one from. there are none on ebay.
Posted 16th Feb 2012 at 21:18
wilyoldave
Green plug? £22 approx from main stealer
No more peugeots Sad
Snap - no more RS clioSad
Now Ph1 RS clio Smile
Posted 16th Feb 2012 at 21:21
slywhite
cheers fella, will get one ordered tomorrow. its the green one i need.
Posted 16th Feb 2012 at 21:29
Quite a common failure actually these green CTS's.
Glad you got to the bottom of the problem. Smile
Posted 17th Feb 2012 at 07:18
