Author Subject: Air Bag light problem? Please help!
dj_rykos
I have the usual Air Bag dashboard flashing light problem on my Phase 3 306 HDi.
I disconnected the two orange cables under the driver's seat and used bullet plugs to securely reconnect them.
To my dismay, upon turning the key again - the Air Bag light still flashes.
Does this mean the problem is in the wiring loom behind the sterring column?
Could the problem be anywhere else?
How much is it likely to cost to repair?
Posted 18th Dec 2011 at 17:56
justinaccurate
The "Air Bag" light is for the steering wheel / passenger dash air bag, make sure the passenger air bag switch is set to "on" (just near to the ignition)
The side air bag symbol is related to the side airbags on the font seats, if you have done the drivers side it could be on the passenger seat?
Posted 18th Dec 2011 at 18:01
colgti6
If all else fails take the bulb out
Adding up the bills for the 6
Posted 18th Dec 2011 at 18:52
tarret
The air bag fault light may need to be cleared using diagnostic test
Posted 18th Dec 2011 at 19:04
aaron6
Check the ones under the passenger seat
Posted 18th Dec 2011 at 19:36
dj_rykos
Thanks for the advice. I've just done exactly the same bullet-plug replacement with the orange cables under the passenger seat, but I am greeted with exactly the same glashing Air Bag light on the dash still.
What would be the next port of call in stopping the light?
I don't care whether the air bags work or not!
Posted 24th Dec 2011 at 18:35
atterz
Take dash out and remove the bulb.
owain wrote:
that'll be a big fat FAIL next year.
Posted 24th Dec 2011 at 19:04
dj_rykos
How long does it take to remove the dash?
Posted 24th Dec 2011 at 19:34
fatlapit
2hrs
Posted 7th Apr 2012 at 15:02
mrdeey
Try a ecu reset , its in the FAQ section on here , it might just fix the prob , i soldered the bas**rds on my wifes cab in the end !
now new booted , boosted and flying again!
Posted 8th Apr 2012 at 21:09
gilesy
Or for MoT, wire the airbag light to the alternator light. They'll both illuminate for ignition, and disappear when started.
Cashback
Posted 9th Apr 2012 at 02:22
mik
Not any more thanks to more Brussels interference.
To save the effort of clicking the clicky, the key quote is:
"Until now, for example, those with airbag lights that remain on while driving have passed because it's an issue that hasn't formed part of the safety inspection. Now drivers will no longer be able to simply remove the bulb, as it will have to be shown working when you turn on the ignition, and go out once it is started."
Cherry Rallye SOLD
Posted 9th Apr 2012 at 13:32
I can see a demand for a small simple timer circuit to power warning lamps that takes a feed from the accessory position on the first turn of the key, and then holds 5-10 seconds of charge via a capacitor once the key is turned to the running position and then the supply is cut.
Posted 10th Apr 2012 at 10:44
