black and gold
| Author | Subject: ecu locked out? |
panks blaze
Junior User Location: Ilkeston Registered: 26 Apr 2008 Posts: 67 Status: Offline |
went out this morning to start my car and it wont fire up.someone said my ecu could have possibly locked out.how can i tell if this has happened? ________________________________________ black and gold |
Not sure if there is a way? Don't think it should just lock itself though,you have done nothing to car?unplugged ECU etc? Your key hasn't fallen apart has it? ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
simonjames
Seasoned Pro Location: Whitland S.Wales Registered: 23 Nov 2004 Posts: 6,219 Status: Offline |
When ignition is switched on does the fuel pump prime up ?________________________________________ All South Wales Members Click HereTeam Supercharged Black RALLYE ™ (Click Here for Build Project) MY EBAY ITEMS 07943066306 |
matt evans
Seasoned Pro Location: Stourbridge Registered: 16 Sep 2009 Posts: 2,290 Status: Offline |
coskev wrote: Not sure if there is a way? Don't think it should just lock itself though,you have done nothing to car?unplugged ECU etc? Your key hasn't fallen apart has it? Ive umplugged my ecu and removed it from the car. The battery had long since been disconected. Will that have caused any issues for me Kev? ________________________________________ 1999 Astor Grey GTi-6 OEM+ (now gone...)2004 Aegean Blue 206 GTi 180 (also gone...) 2006 Skoda Fabia vRS in Sprint Yellow honestly3k wrote: Do you wrestle for a living matt? You sound like a monster ![]() owain wrote: Nothing involving a 306 can be considered worthwhile. |
Nope should be fine |
panks blaze wrote: went out this morning to start my car and it wont fire up.someone said my ecu could have possibly locked out.how can i tell if this has happened? Have you checked the knock sensor ? Big red button to right of engine bay ? It should be pressed down |
panks blaze
it turned out to be the main fuse on the fuse box (green and grey) had somehow come out a bit.thanks for the info though.________________________________________ black and gold |
pugjim
Seasoned Pro Location: Sheffield Registered: 11 Mar 2007 Posts: 1,380 Status: Offline |
bigbadbowen wrote: panks blaze wrote: went out this morning to start my car and it wont fire up.someone said my ecu could have possibly locked out.how can i tell if this has happened? Have you checked the knock sensor ? Big red button to right of engine bay ? It should be pressed down Thats not the knock sensor, thats the inertia fuel cut off switch to cut the fuel if you have an accident. The knock sensor is bolted to the block and detects knocks/pinking in the engine and adjusts the timing to prevent engine damage. |
Does it have a knock sensor? Where is it?________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
stan_306gti6
buzzbrightyear wrote: Does it have a knock sensor? Where is it? Bolted to the front of the block with a 13mm bolt inbetween 2 & 3 cylinders. I'm not 100% sure Andy, but I think on our setup it is not used and left unplugged... ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
well Ive never noticed that before or even herd it mentioned on here. ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
pugjim
All gti6's have a knock sensor, even the s16's too. Its a round sensor bolted to the front of the block in the middle, just below the head. Has a wire and green 3 pin plug on it. |
stan_306gti6
buzzbrightyear wrote: well Ive never noticed that before or even herd it mentioned on here. It wouldn't run very well on the Pug ECU if it wasn't there Andy... ![]() As I say I am pretty sure the DTA doesn't use it as an input. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
