Was fine for a few days then the gear box has decided to start leaking any idea if it's the drive shaft seals or the diff that could be leaking cheers in advance
Adding up the bills for the 6
| Author | Subject: Gearbox leaking |
colgti6
Regular Location: maidstone Registered: 16 Jul 2011 Posts: 131 Status: Offline |
Done an engine and gear box change the other day on my 6, itWas fine for a few days then the gear box has decided to start leaking any idea if it's the drive shaft seals or the diff that could be leaking cheers in advance ________________________________________ Adding up the bills for the 6 |
Depends what's leaking out, if it's oil you may have dislodged a driveshaft or damaged a seal. If it's leaking milk, you've probably filled it with dairy instead of the correct oil.Best bet is get some good degreaser on the go and get it all clean so you can see exactly where the leak is coming from, because either is feasible. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
matt evans
Seasoned Pro Location: Stourbridge Registered: 16 Sep 2009 Posts: 2,290 Status: Offline |
Did you change the driveshaft seals for new Pug ones? They are dead easy to nick with the spline of a driveshaft and then they leak. Oil has a habbit of getting everywhere, so like Owain says, get cleaning first.________________________________________ 1999 Astor Grey GTi-6 OEM+ (now gone...)2004 Aegean Blue 206 GTi 180 (also gone...) 2006 Skoda Fabia vRS in Sprint Yellow honestly3k wrote: Do you wrestle for a living matt? You sound like a monster ![]() owain wrote: Nothing involving a 306 can be considered worthwhile. |
they arent meant to be fitted flush, 1.5mm one side and 1mm tother iirc.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
colgti6
No didn't change the drive shaft seals, but I have phoned up for a price £8.99 which ain't to bad ________________________________________ Adding up the bills for the 6 |
get them from your local if they do febi, £6 odd the pair.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
smithers
Seasoned Pro Location: Glasgow Registered: 22 Nov 2004 Posts: 1,016 Status: Offline |
welshpug! wrote: they arent meant to be fitted flush, 1.5mm one side and 1mm tother iirc. Pressed in a further 1.5mm or protruding 1.5mm?? ________________________________________ 1997 Black GTi6smithers205 at hotmail.com |
definitely not further in ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
darkgti6
Seasoned Pro Location: Bracknell Registered: 07 Jun 2008 Posts: 1,361 Status: Offline |
ive hit them all the way home twice and never had a leak.________________________________________ Team Peugeot Sport 308 Gti�Black T'99 Gti - may she rest in peace - written off in a shunt on the A329m |
darkgti6 wrote: ive hit them all the way home twice and never had a leak. Me too twice, the drivers side never leaked but the p/s did both times slightly ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
must have struck lucky.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
I always put them flush, always been ok too. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
