displaying posts 1 to 2 of 2
Author Subject: ICV active at 1500rpm?
lewisdmz
Does the ICV only come into play when the engine is at idle speeds? I'm having a bit of rough running/occasional stalling issues - the car idles well but if I open the throttle a little bit the response is aweful until it gets to about 1500rpm and then it will rev up suddenly(despite me only opening the throttle a tiny bit).
From reading through other threads I'm thinking MAP/TPS/lambda/ICV.
To test the MAP sensor it says do not disconnect multi-plug - what's the easiest way to access the plug terminals?
Posted 14th Dec 2011 at 13:15
mabgti
NV motors
My guess is TPS
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 16th Dec 2011 at 01:51
