Author Subject: Crunching 4th gear
southernfool
Good morning guys,
My gears have been a bit stiff to get into for a while, and 4th has been crunching, so I got a new clutch cable which made a massive difference to the other gears however my 4th gear still crunches after about 40mph, any ideas?
Could gear linkages cause something like this or am I more likely looking at a messed up clutch of gearbox?
Posted 9th Dec 2011 at 10:14
synchro or synchro spring slip thingy.
checked your gear oil?
Posted 9th Dec 2011 at 10:22
southernfool
Cheers,
Are they easy or expensive fixes if so (Synchro)? Guess thats a bit how long is a piece of string.
I will check my gear oil, all the other gears seem pretty damn smooth though.
Posted 9th Dec 2011 at 10:31
mattgti6phase2
Check the oil level first and what grade is in there? I recently found out my box had sx 75/90 in which caused a crunch into 2nd now I have put the correct stuff in and the box is now faultless Smile
You could get the 3rd/4th gear hub rebuilt for about £150 but maybe a second hand box would be the better option.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 9th Dec 2011 at 11:31
Miles does pug gearboxes, drop him an email Thumbs up
Posted 9th Dec 2011 at 11:49
miles
Not a cheap fix, labour to remove and refit the box if not off, Then the box, New Hubs are around £190 with VAT from Pug or S/H around £40.00, labour to strip clean and check it all over then I always recommend new Input shaft bearings as these do wear, re-shim, New seals (OE) so around £550.00 all in depending on parts
www.pugracing.com
Posted 9th Dec 2011 at 14:00
123456
Dibs on it just needing OE gearbox refill.
Aka Manstoner
Aka Clio dumper
Aka PrinceofPeugeot
Aka Decat raspberrys
Posted 9th Dec 2011 at 14:02
gazzerdaman
Dibs on it being the synchro ...
Mine does exactly the same dropping down from 4th to 5th if the revs are low. Have just learnt to match the revs.
With the revs right it's the best gearchange in the box !
Gary
Cherry Red GTi 6
Posted 10th Dec 2011 at 04:56
justinaccurate
Mine had something wrong with the box not mentioned above... I remember Carl posting pics of virtually no teeth left
Posted 10th Dec 2011 at 10:43
