The problem is it randomly shows different levels. Sometimes on the white mark just before the red and other times half way. It used to just sit on the white mark near the red. The oil is correctly topped up and the car is driven each day.
| Author | Subject: Oil Level Gauge Q |
iplay
Seasoned Pro Location: Number Wang Registered: 18 May 2006 Posts: 3,272 Status: Offline |
On startup. key in 2nd position. oil gauge shows the oil level.The problem is it randomly shows different levels. Sometimes on the white mark just before the red and other times half way. It used to just sit on the white mark near the red. The oil is correctly topped up and the car is driven each day. |
nothing out of the ordinary I'm afraid, not unknown for the wiring to be damaged though.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
russbez
mine does this sometimes, i just thought it was dodgy earth or some sort of sensor on its way outdone it about 2 month ago, hasnt done it recently dont we mean "oil temperature gauge"? ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
probably does if its a phase 2 ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
iplay
russbez wrote: mine does this sometimes, i just thought it was dodgy earth or some sort of sensor on its way out done it about 2 month ago, hasnt done it recently dont we mean "oil temperature gauge"? yesish .. oil level gauge ... *edited* |
iplay
welshpug! wrote: nothing out of the ordinary I'm afraid, not unknown for the wiring to be damaged though. the sensor moves everytime so i don't think the wiring is damaged. where is the sensor located and how does it work? |
monkeyman
Seasoned Pro Location: Sunny St Albans Registered: 01 Oct 2008 Posts: 1,955 Status: Offline |
The sensor seems very sensitive, where I normally park is good and flat, but anywhere with a bit of camber and I get low readings.________________________________________ Spanner Monkeys Monkey SpannerForum Search Clicky |
on these engines its in the front of the block pointing down into the sump, unsure on exactly how it works though.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
