Author Subject: Front wiper problem
mark.evs
I've read through most of the Q&A's on here and cant find anything that has worked so far. The front wipers on both my 6 and D-turbo have the same problem, they only work on slow speed. I've swapped the switchs and relays with spares i have and also bought a new motor from valeo (at £93!) and both cars still are still the same.
Does anyone have any other ideas? the spare switch and relays worked fine in my last 306. i'm really stumpped.Sad
My GTi6 track project
White Rallye project
Posted 28th Nov 2011 at 14:55
check the contacts in the plug on the motor.
Posted 28th Nov 2011 at 14:59
mark.evs
Thanks for reply, i just had a look now outside work, they look ok, gave them a bit of a scrape with a pick too, still the same. i'll get the electrical tester out later and see from there.
Posted 28th Nov 2011 at 16:31
mabgti
NV motors
Youll have to take the motor assamble apart and clean the contacts on the swing contact. Easy job.
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 30th Nov 2011 at 01:20
even with a new motor mab? Wink
Posted 30th Nov 2011 at 09:03
mark.evs
I took the old motor apart for a giggle and 2 connectors were ok but the 3rd was dead, i also checked the feed to the motor, 1 positive all the time, 1 positve on click 2 of the switch and nothing on the other 3 contacts. guessing 1 is earth mind. I think its all gone down at once, Sods law i'll have 3 duff switches an 2 duff motors. I dont think the new motor will be faulty too. i'll get a new switch and try that too. I've also taken the switches apart and cleaned it but there's not alot to go wrong in there. any more ideas?
Posted 1st Dec 2011 at 14:48
simonjames
is the switch sending supply from each possition
MY EBAY ITEMS
07943066306
Posted 1st Dec 2011 at 15:06
mark.evs
it was too late for me to test feed from there, i'll check tonight and report back, i did pull the lead out and try another switch but it was exactly the same.
Posted 1st Dec 2011 at 15:59
simonjames
Auto/non-auto switch ?
MY EBAY ITEMS
07943066306
Posted 1st Dec 2011 at 16:03
mark.evs
not sure what u mean, the switch has push/hold down for wipe, intermittant, 2 speeds and rear wash wipe. rear works fine, as does the push/hold down for wipe and the slow speed. it also doesnt park in any speed.
Posted 2nd Dec 2011 at 15:18
