Author Subject: Boot Lock
anth
Hi,
Phase1 Dturbo the boot mechanism has stopped working, where by the button just stays stuck in when ive pushed it and the boot wont open and have to prise it back out again. Im guessing the lock has had it might try filling it with WD40 though first.
Will any boot lock be OK from a phase1 if i do have to replace it?
Thanks
Posted 28th Nov 2011 at 12:47
grumpychef
The Rib Man
i would have thought that wd40 was good as a water dispersant and penetrating oil but 3 in 1 would be a better lubricant but it might be a good idea
Formally team BLAZE now Team bianca recuperating from multiple organ failure nicely!
items replaced so far, clutch, cambelt etc, radiator, exhaust, most of front running gear, wish bones, drop links, ball joints, track rod ends, bearings, brakes, calipers, discs, and pads, brake lines, front springs, brake balance compensator thingy, hand brake cable, throttle cable (twice), coil pack, door handle, windscreen, wipers, head lamps several sensors and bulbs Dry .rear beam new throttle cable, new battery. .......... yeah man, team money pit! but shes still rollin!
Posted 28th Nov 2011 at 18:52
mik
Dismantle it and see if something is broken, if not lube with white lithium grease (available in spray cans in 3-in-1 brand) or similar.
Cherry Rallye SOLD
Posted 28th Nov 2011 at 22:29
anth
OK il give it a go, I assume removing it is fairly self explanitory?
Posted 29th Nov 2011 at 06:36
