Author Subject: solid crank pulley
JWP EFi
Turbo Legend!
does any of the XU engines use a solid crank pulley, ie, without the rubber insert? was thinking 205 gti maybe??
i need to mount a trigger wheel on to it so i can use cossie management, i know there are custom aluminium pullies
available but my trigger wheel is steel and ideally want to spot weld the 2 together.
As always, any info would be much appreciated
cheers
Posted 27th Nov 2011 at 10:19
aaron6
See if richw can machine a solid billet steel one. Its only a case of changing speeds and feeds on the cnc lathes manual over rides. Thats what id do anyhow, the program will remain the same.
Posted 29th Nov 2011 at 10:16
I take it the Cosworth management is 36-1 instead of 60-2?
Posted 29th Nov 2011 at 11:06
The cast pulley won't weld very nicely to a mild steel trigger ring anyway, the welds will vey likely crack out of the pulley as they cool. Dowels and loctited bolts are the best method of securing something like that.
Posted 2nd Dec 2011 at 13:08
JWP EFi
Turbo Legend!
Its neither, it uses only 4 teeth spaced 90 degrees apart, iv'e never seen this kind of trigger before
would have been nice to machine counting teeth off of pug flywheel and then somehow fit new ones, but too much
margin for error me thinks
if cossie had used a 6 rib belt instead of vee type then i would have looked into machining one of those to
fit XU crank
oh the joys of modifying!
Posted 4th Dec 2011 at 12:09
